Computers & Internet Logo
Posted on Oct 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can connect to handset please? when I buy the phone have 2 handset,but no book basic setup..model DXI5686-2
Anonymous
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 185 Answers
  • Posted on Nov 03, 2009
Anonymous
Expert
Level 2:
Mentor:
Answers
185
Questions
9
Helped
39219
Points
375
Only one socket will fit
good luck
Handset display says "Connecting" I can't deregister. How can I get the handset to display "not registered"?
The procedures to deregister are, of course, specific
to each make and model number of cordless phone.
All of them are a LOT more involved than simply
removing the battery.
For some AT&T, VTech, Uniden, & GE model numbers
you might try the following:
For many AT&T models it is simple:
1. When the handset says "Connecting..."
enter *331734 [menu]
it will soon (chirp) and display "Not registered"
For many VTech models it is a bit more involved:
1. Start by taking off the battery compartment cover.
2. press [menu]
3. scroll up/down to "Settings"
4. enter * 7 8 9 0 #
5. if display reads "Test Base",
scroll to "Test Handset", press [select]
scroll to "next page", press [select]
6. scroll to "Register Clear?", press [select]
7. display asks "Confirm?" or "Register Clear??",
press [select]
8. display reads "Ok" (chirps), press [ off ]
9. UNPLUG THE HANDSET BATTERY
(this is why the cover is off)
10. Wait ~30 seconds, re-connect the battery &
replace the cover
11. display reads "Not Registered"
For many Uniden models:
1. Press and hold the [END] and [ # ] keys at the
same time, after a few seconds the display reads
2. "System Reset, Deregister Handset"
3. scroll to "... Base Unavailable"
press [SELECT]
4. Handset (chirps)
press [END]
5. display reads "Not Registered, Place in base..." =====================================
For some GE models:
1. press "program[mute]"
2. scroll to "Handset Setup" press "program[mute]"
3. scroll to "Deregistration" press "program[mute]"
4. scroll to "Yes" press "program[mute]"
5. display reads "Not Registered"
Once you have the handset displaying "Not Registered"
you can follow the User's Manual instructions to register
the handset.
The model number for your cordless phone is shown on
a small sticker underneath the battery in the handset --
enter this number at www.manualslib.com to get a free
copy of the User's Manual if you need it.
9answers
LG-Nortel LDP-7024D Handset connecting to GDK100
try to check the telephone wire connections. or try to use the other phone box to test.
I have registered a (different make) GAP compatible phone with my base station and can get a dial tone but no other functions ie address book. Any suggestions?
Yes, buy the correct one and follow the instructions in the manual. We are unable to give advice when you won't say the make and model of your base station or the (Different make) handset. I mean, does your new handset even have an address book function? Does your base station have an address book function?
1helpful
I want music player software.
nokia3110 is a basic model if any problem occurs in application
there you need to update your handset.
This is because there no any software available for this basic handset.
So please visit the nearest nokiacare and get your handset FLASHED.
Thank
Lost book need to reset my answering machine when someone calls
Answering system settings
Announcement
The telephone is preset with a greeting that answers calls with "Hello, please leave a message after the tone." You can use this preset announcement, or replace it with your own.
Play your announcement
Press MENU/SELECT to show the menu when the handset is not in use.
Press MENU/SELECT to select >ANS. SYSTEM.
Press or to select >ANS SYS SETUP, then press MENU/SELECT.
Press or to select >ANNOUNCEMENT, then press MENU/SELECT.
The handset announces, "To play, press 2. To record, press 7." Press 2 to play.
Record your own announcement
The handset announces, "To play, press 2. To record, press 7." Press 7 to record.
The handset announces, "Record after the tone. Press 5 when you are done."
After the tone, speak towards the microphone of the handset.
Press 5 when finished.
The answering system automatically plays back the newly recorded announcement. Press 5 to stop the playback at anytime;
Your manual can be found at:
http://vt.vtp-media.com/ecp/documents/product_Product/36/UserManual/1279/cs6229-3_manual_i5.pdf
3helpful
LHow do I increase the volume as the phone is very quiet
Hello there,
Adjusting the volume on an HP Officejet All-in-One
Follow these steps to adjust the volume of the various fax sounds.
Adjust the rings and beep volume
1.Press the Setup button P(wrench).
2.Press the arrow buttons (Left and right) to select Basic Fax Setup , and then press OK .
3.Press the arrow buttons (Left and right) to select Rings and Beep Volume , and then press OK .
4.Press the arrow buttons (Left and right) to adjust the volume, and then press OK .
Adjust the phone line and monitor volume
1.Press the Setup button (wrench).
2.Press the arrow buttons (Left and right ) to select Basic Fax Setup , and then press OK .
3.Press the arrow buttons (Left and right ) to select Phone Line, Monitor Volume , and then press OK .
4.Press the arrow buttons (Left and right ) to adjust the volume, and then press OK .
Adjust the handset volume
When you receive a call, pick up the handset of the product, and then press the arrow buttons (Left and right ) to adjust the handset volume.
Please feel free to leave a testimonial if this works and please do not forget to click 4 thumbs.
Cheers!
Mordem
Yes you can use your handset as a modem infact most modern handsets are able to be used as a modem , but before you attempt to connect please chack with your network operator as  charges may apply depending on the network you are using.
There are a number of ways to do this but to start off with you need to make sure that the handset itself can actually access the internet
Settings can be obtained from your network.
Once you have checked the above with your network provider then the most simple way to connect is by USB. firstly we need to check that your phone is correctly setup
1. Go to the main menu
2. Select Settings
3. Press joystick left so that you get to the connectivity menu
4. Select USB
5. Select USB Internet
6. Select Turn on then OK
7. Select USB data accounts
8. In your list of accounts select the one that your network provider setup with you ( If it was already setup select the account that has interent after it , you may have a picture message or mms option do not select these it will not work )
9. Now return to your standby screen
That is your phone now setup.
Using the USB cable and sony erricson PC suite software included firstly install the software then connect the USB cable to PC and phone.
After a few seconds your phone will provide you with a list of options select phone mode. after a while you will see the globe symbol on your phone and your PC will show it is connected to the interenet . Happy browsing .
If you wish to connect by bluetooth please contact me and I can provide further help .
Grand Canyon Tech
Grand Canyon Tech
