Question about Cuisinart CBK-200 Bread Maker
Bread container won't stay seated
I've had a CBK-200 bread maker for approx 1-1/2 years. Occasionally when the kneading process begins the container pops up and unseats from the paddle driver. Now it is more frequent - it popped up 8 times during the making of a batch of brioche yesterday - since you are supposed to be able to walk away and leave the machine to bake a loaf of bread this is not acceptable. I'm ready to take it to the dump.
  • 7 more comments
  • ivabanjo Jan 06, 2008
    I have the same problem. I thought maybe I wasn't getting the pan secured, but I am sure that I do. Yes, I do not like this.
    why is this happening?
    ivabanjo
  • wantBread Jan 16, 2008
    I also have the same problem. I started searching on the internet out of frustration, to see if others were experiencing this as well. I received my breadmachine 1 year and 1 month ago. The problem started 3 months after that. Same thing: once the dough starts to get stiffer in the kneading process, the bread pan pops out. I just finished holding it down for 30 minutes myself!
    I tried bending the side brackets out for a tighter fit, but that didn't work.
    Would be great if someone had a solution.
  • Anonymous Mar 05, 2008
    I have the same problem. The bread basket does not remain seated during the whole duration of making the bread and requires holding it or propping the basket with an oven mitt in the machine for every function prior to baking which is when i take it out. Not good if you want to bake while you are not at home.
  • dietermg Mar 29, 2008
    We have exactly the same problem. It started from the beginning.
    Solution#1:
    Found a partial solution: The basket pops out mostly on one side. When we turned it 180 degrees if would only rarely pop out. We marked the basket and the snap-in bracket with a marker. Now it only pops out accasionally.
    Solution#2
    Another solution is to hold it in place with a kork from a champagne bottle (not plastic but cork). Not a highly technical solution but it works.
    So far we like this breadmaker except for the poorly designed snap in brackets.
    I can't say anything about the quality and/or durability as we have it only since 3 months.
    DMG
  • Anonymous Jun 13, 2008
    Add me to the list! We're having the same problem. Husband propped up handle, closed lid on it to keep it in place, then place cast iron pan on top to hold it. I don't see this as a long term solution, however!
  • SheltieMom Aug 15, 2008
    The tip of using a champagne cork works like a charm.  Thanks
  • Anonymous Jan 10, 2009
    the pan pops out if its brackets constantly when kneading
  • Anonymous Jan 31, 2009
    Ours is brand new and has the same problem - love everything else about the machine, but the bowl won't stay seated..
  • alpha79 Mar 17, 2009
    I have the exact problem. I returned my first unit, and now the second unit is doing the same thing. It's very frustrating, though I love the idea of the cork. I will try that. Do you wedge it between the basket and the side of the unit? I will also try turning it 180 degrees and see what happens.
I had the same problem. I bent the spring tabs out and it helped a bit. I then made sure the breadpan was straight across the top. That seemed to do it. Only problem now is that I can't find the kneeding paddle.
Posted on Jun 24, 2008
I just used my new Cuisinart bread maker for the first time and have the same problem. I feel that for the money this machine costs and the quality that one would expect from Cuisinart, they should have fixed the problem in their design and production or pulled the product. This is not happiness making and consumers deserve better than having to experiment with corks and frying pans to get their breadmaker to work! Very disappointing.
Posted on Aug 03, 2009
I had the same thing happen to me. When I called cuisinart they said there was no oter way to fix it besides pulling up the hinges which did not work for mine so i exchanged it and the new one seems to be fine so far....
Posted on Mar 10, 2009
I was lucky in that my bread machine was still covered by the warranty. I received a new unit from the company with the remaining warranty on it and haven't had a problem with the new machine at all.
Thanks to all for your input - I always to tend to think I must be doing something wrong!
Bread won't rise....
Forget the white bread recipe in the Cuisinart book. There is an error in it. Is that the one you were trying to bake?
Feb 08, 2013 | Cuisinart CBK-200 Bread Maker
Bread maker won't mix, it just clicks. I removed two screws on the bottom to see if the belt had slipped off. it was fine so I called Cuisinart to see if they could help. They said removing even one...
Some bread machines warm up before the kneading process begins especially on whole wheat cycles. If your machine hasn't started kneading after about 1/2 hour then you do have a problem but, give it time before you give up on it....
Aug 24, 2011 | Cuisinart CBK-200 Bread Maker
Bread pan bounces on paddle rotor during kneading process
Make sure you have the pan snapped in between the two springy clips at the top of the oven cavity. Also make sure you have the pan all the way down on the shaft. If there's something in the hole for the shaft, it won't go all the way down and engage the shaft properly.
Mar 04, 2011 | Cuisinart CBK-200 Bread Maker
My bread pan becomes dislodged many times during the kneading cycle. I have to reset the pan and then continue the cycle. This is a new problem with my Cuisinart Bread Maker. Thanks for your help.
There should be some metal tabs that hold the bread pan in that machine. You probably have to push the pan over them to get it to stay. These become weak sometimes and you just need to try to stretch them out from the inside wall of the bread maker. You want them to stick out more so it puts more pressure onto the pan. Let me know if this doesn't make sense and I'll see if I can explain it a little better. Austin
Feb 28, 2011 | Cuisinart CBK-200 Bread Maker
My bread machine (CBK-200) worked beautifully for over a year, but then I started noticing that I couldn't get the bread pan to click into the base like before. Now, when it's in the kneading cycle the...
reach in with your fingers and bend the two little clips out a little until they grip your pan snugly. Start with 1/4 " and try that. If it doesn't feel snug go another 1/4 inch.... and so on....
Jan 19, 2011 | Cuisinart CBK-200 Bread Maker
Clicking noise when on the knead cycle and the kneading paddle doesn't turn at all. I have only had the machine for 1 year and no longer have any receipts.
I am having the same problem. I just purchased my machine last week. I made regular white bread last week and it worked great, but today I tried to make whole wheat bread and it froze. Any solutions for this?
Cuisinart CBK-200 Bread Maker Logo
540 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dale Anderson
Dale Anderson
Level 1 Expert
Tom Chichester
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
