You can do it by loading the new firmware on a USB key...but it is pretty complicated and the firmware is only available with a password at the Toshiba website....if you make a mistake the copier will be unusable...
Best to call a Toshiba tech
How do I set up a toshiba 232 multi function copier/scanner/fax as a scanner in the computer so that...
(More)
How do I set up a toshiba 232 multi function copier/scanner/fax as a scanner in the computer so that software sees it as a scanner not a printer?
I just bought a used print/scan enabler for Toshiba Studio 202L pn# GM-2080U. There are no...
(More)
I just bought a used print/scan enabler for Toshiba Studio 202L pn# GM-2080U. There are no instructions with it. Where is the USB port it plugs into and how do I go about installing it?
