Question about Quantaray 28-200MM F3.8-5.6 Lens for Canon AF
Flash problems with Quantaray 28-200MM F3.8-5.6
I have a sony a a100 that i am using Quantaray 28-200MM F3.8-5.6 for minolta on. It works fine for outside pictures, however, the metering doesn't seem to work....all my pictures come out dark. Also, I will occassionally get a reading on my camera that says "no lens attached". Any ideas?
thank you
Joe
713-545-45962
turfman@golfturfs.com
  • doodie25 Mar 04, 2008
    I have the exact same problem with my Milnota Quantaray lens when attach to sony a100 - works without a flash but as soon as I flip up the flash and take pics indoor/low light etc, they all turn out obvious issue ridden dark or even black. I had just gotten the lens back from Ritz after 5 weeks - they fixed a gear issue and now this is occurring. Thoughts? I am taking it back to ritz to correct but unfortunately they take 4-6 weeks to repair anything.
Try setting the camera to the Aperture Mode A or the Manual Mode. I am assuming that you are using the AUTO mode and due to this the aperture is set really high may be a 60 ( read the green text through the eye piece and the second number will be the aperture number)
With a low aperture number like 5.6 or so the photo should be clear and not dark. I am not an expert user but this could be a solution if the problem was occurring when the camera was in AUTO mode.
mshaik@gmail.com
Posted on Jun 02, 2009
    Scholar:
  • 39 Answers
Try using an external flash. even if you just borrow one inside the camera store. make sure that i isnt just the lens being too long for the on camera flash.
as far as not working all the time. that is a little more complicated. I would go back to the camera store where you said you took it and ask them to call their repair center and give you sigmas address. if you send it to them directly then there is no fee to have it checked out. and you will actually get it back quicker.
Sigma is the one that made that lens for quantaray.
Posted on Jul 02, 2008
Quantaray 70 - 300mm for Minolta AF (25-166-4546)
Check you manual, but it should be no problem- Sony bought Konica Minolta to have the Minolta lens mount (and engineers). Your old lens doesn't have all the internal electronics (and connections) of the new lenses, but every old minolta AF lens i've tried works fine with alpha
May 02, 2010 | Quantaray Tech-10 70-300mm f/4.0-5.6 Lens...
I hav a Quantaray 9550 with a module to fit a Minolta Maxxum xtsi. Can it be used with a sony alpha?
Yes, it can, but you will likely loose some of features that make the 9550 such a nice flash.
Better bet, contact a dealer for Quantaray and buy the Alpha module.
Aug 22, 2009 | Cameras
Sony a100 match ups
Yes, when Sony took over Konica Minolta they inherited the Maxxum lens mount (Minolta's AF lens mount system). the only Minolta lenses which don't work are the earlier manual focus type.
Sony have finally launched three new models which are the first to be clearly Sony designed, but they have still retained the Maxxum lens mounting.
Jul 03, 2009 | Sony Alpha DSLR-A100 Digital Camera
QUANTARAY QBX-8000xi Flash for SONY ALPHA - 350 digital SLR
Unfortunately not.
This flash is a superb budget alternative to the Minolta alternatives but is only suitable for their film cameras. Sony's SLR's are based on the later Minolta Digital SLR's and they're all incompatible with this flash.
The technical differences between the film and digital Minolta cameras explains why a Minolta 5600HS (for example) had to be redesigned and redesignated as a 5600HS(D). The former will not work on Sony Alpha models, but the latter is fully compatible.
May 13, 2009 | Quantaray QBX-8000XI Wireless Remote Flash
Used on a Minolta Maxxum 800 si
Hello
The Minolta AF lens will fit and work on most of the Minolta AF bodies (it will depend on exactly what lens it is as to the compatibility), you will also find that it will fit and work with the new range of Sony
digital SLR camera bodies.
The Quantaray lenses are a little bit more difficult as Quantaray make lenses for several different types of camera body, it should mention on the lens what make the lens mount is for. If you post further information about the lenses it might help.
Sep 19, 2008 | Quantaray 100-300mm F4.5-6.7 Zoom lens for...
Quantaray 7500 flash
You will need a minolta pct-100, the will allow your flash to work with your Sony A-100
May 22, 2008 | Sony Alpha DSLR-A100 Digital Camera
QUANTARAY FOR MINOLTA AF 70-300MM compatibility
Usually mounts are unique to a camera manufacturer. There are exceptions. Sony has the Alpha; lenses for the Konica-Minolta are the same mount. Your AF (autofocus) lens will work on it. You might also consider picking up a Konica Minolta 5D or 7D.....they're no longer made and hence are cheaply had.
The MD and Rokkor lenses won't work on the Sony Alpha.
THIS IS A CHEAP LENS (<$50 VALUE) SO I WOULDN'T LET IT DRIVE YOUR DECISIONS!!
Jan 19, 2008 | Quantaray 50mm f/2.8 AF Tech-10 for Canon...
Quantaray tech-10 24mm f2.8
Yes, I have this lens and it works just fine with Sony alpha A100
Dec 21, 2007 | Quantaray 50mm f/2.8 AF Tech-10 for Canon...
AF problem with Quantaray 2X adapter
How does it stop working? Do you mean it doesn't auto focus anymore?
Many longer focal length lenses wont auto focus with 2x teleconverters on them.
Nov 27, 2007 | Quantaray 100-300mm F4.5-6.7 Zoom lens for...
Quantaray QBX-8000xi owners manual
1. No.
Unfortunately not.
2. I haven't managed to find a manual for this model in my stock room and failed to trace one online.
Nov 01, 2007 | Cameras
Quantaray 28-200MM F3.8-5.6 Lens for Canon AF Logo
141 people viewed this question
Top Quantaray Cameras Experts
Steve
Jerry Greenberg
Jerry Greenberg
teddyboy
Are you a Quantaray Camera Expert? Answer questions, earn points and help others
