HP1907 goes to sleep if not used for a little while and does not get back on unless the computer is switched off and on again. This is very frustrating and I hope there is an easier way to get back or turn the sleep mode off
Monitor flickers when starting up; flickering is particularly noticeable when streaming videos; and...
(More)
Monitor flickers when starting up; flickering is particularly noticeable when streaming videos; and there is a black boarder running on top of screen -- getting larger; chatted with HP -- suggested that a health check be performed on video card (loaded on motherboard) -- PASSED -- determined that it was a monitor malfunction and that I should purchase a new monitor (?; the monitor was purchased 12 mos ago (entire PC package) -- can this problem be repaired or should I indeed purchase a new monitor? Thank you.
Having the same "going black" problem with my HP w 1907 after about a year. Can anyone...
(More)
Having the same "going black" problem with my HP w 1907 after about a year. Can anyone tell me if they found it to be their computer or the monitor before I spend unnecessary money trying to figure it out.
My monitor won't connect to my chassis. I run a 9600GTX which has always worked when connected to...
(More)
My monitor won't connect to my chassis. I run a 9600GTX which has always worked when connected to the monitor. For seemingly no reason the monitor no longer accepts its signal. I've tried alternating between both open ports on the card and from DVI and VGA, but nothing yields a result.
