Question about Toshiba 57H81 57" Rear Projection Television
Picture stretch top/bottom for 1080i HD input
I am using component HD cables with 1080i HD input. The picture seems to extend beyond the top and bottom of this screen. This does not happen with 480p HD input, although I have other problems with that.
  • jeff686 Oct 05, 2008
    I have the same problem. No matter what hd source i use (cable box, xbox, etc) all sources are set to 16x9 and 1080i ... any ideas?
  • 206 Answers
First thing to look at would be the source, make sure that this source whatever it may be is set to display a 16X9 format. Your set may simply be showing what it see's and it may be seeing the 4X5 format and giving you a problem
Posted on Feb 13, 2008
  • Akharma27 Jan 04, 2012
    No, I have exact same problem. Source is 16x9, looking for special setup not listed in manual.
The picture seems to have gotten bigger and now the tops of their heads are cut off
When this happens you can try the wide/picture format/view mode button on your television's remote control first. If your remote does not have one or if this does not correct the problem check the resolution on the cable box next. If your television displays 720p make sure the cable box is set for 720p, or 1080i if the television supports that resolution. First you have to make sure your tv in on the right input not the tv tuner input. Then use the hdzoom# button on the cable remote. If you have a satellite remote it might say format or aspect or you might have to go into the cable box/satellite receiver menu and choose 1080i crop or 1080i stretch to get the right picture size.
Feb 12, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
How do i get 1080i, my tv shows im only in 480i. i think i might have it hooked up incorrect. my other tv of another brand is much newer so all i did was connect the hdmi cable from the tv to the cable box...
Your TV will display all High Definition signals as 1080i True HDTV™ and all standard definition signals will be displayed as 480p.
Component Inputs 1-2
These inputs can be used for the connection of A/V equipment with component video outputs, such as a DVD player or external HDTV receiver. Please see Appendix B for signal compatibility.
Input DTV (480i/480p/1080i)
This input is used to connect an external DTV receiver, and can be configured for YPrPb and RGB plus H&V signal types.
As a special feature, you have the ability to adjust the red and blue light beams in reference to the fixed green light beam. This process is called convergence. There are two separate memories for convergence. One, for SD 480i/480p signals; the other for HD 1080i signals. SD convergence should be adjusted while watching an SD source and HD convergence should be adjusted while watching an HD source.
Wide Expand: Enlarges the picture, cropping some of the image on both sides. This Expand format is useful to remove or reduce black side bars on HD broadcasts of 4:3 images with black bars. Available for analog 1080i, digital SD 16:9 and digital HD signals.
This input is compatible with most standard DTV and satellite receivers with component video (YPbPr) outputs. Compatible DTV signals are SDTV 480i/480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Please check the DTV receiver specifications before connecting.
This input is compatible with some DTV receivers using RGB with "separate H and V sync". Compatible DTV signals are SDTV 480i, 480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Industry standards for DTV RGB signals (systems, synchronization, timing, and signal strengths) are not currently established. These inputs will not be compatible with all DTV receivers that offer RGB, HV outputs. RGB, HV signals with less than 5 cables are not compatible.
If your DTV receiver offers both DTV component video signals and DTV RGB, HV signals, we suggest you use the DTV component video signals. Check the DTV receiver specifications before connecting.
Feb 05, 2011 | Mitsubishi WS-73909 73" Rear Projection...
My sanyo hdtv plasma won't show the whole picture but it worked fine yesterday
Hi my name is Roety,
I can help you with your issue ,
There are a few buttons to adjust the picture size on different make TVs and even on the Cable/Satellite remotes .
First look on the TV remote, set it to Full ,Fill or Just or 16 x 9 (whichever your model uses) Samsung uses the P size button ,
Then on the cable/dish Box remote stretch (not zoom) is usually best.
On the box remote set the output resolution to 1080i only
And use 16x9 when if offers a choice.
Cable remotes use the # key as a zoom/size button.
Due to the fact there are 16 size/Formats available (3 or 4 being transmitted now). you may have to hit the zoom/stretch button on some HD channels.
But with these settings the picture will mostly stay full and help you avoid image burn from the edges being not on the edge.
Stretch will fill the screen and allow you to read the bottom.
Make sure you are on the correct input, sometimes TVs are connected on multiple inputs
(not necessary, only the HD input is needed)
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Dec 15, 2009 | Sanyo DP50747 50 in. Plasma TV
When we watch tv, particularly football, on our lg 50pq30, the tv cuts off the image so we can not see the score at the top or bottom of the screen regardless of which setting we chose
Hello: Seem you are in zoom mode, try hitting the format putton on the televisions remote and if you are using a cable box and using HD check for a picture format or aspect button on it also. You will want to be on 1080i normal or stretched. The cable box and television will use different modes for aspect, try using only one of the remotes when changing aspect ratio buttons or screen size.
Nov 24, 2009 | LG 50PQ30 50 in. Plasma HDTV
Connecting hd cable box to philips 60 rear projection
So, You have Five cable leads, The rgb get plugged into there corresponding colors and the other two are your Red and White Audio Input ------Correct? You do not use the in4, that is for a pc with horiz and vert sync. You use input 1 rgb and plug the red and white into the audio input.....your done!
Jun 06, 2009 | Philips 60PW9363 60" Rear Projection...
KP-53HS10 Real HD
On this TV there is only one input for any HD resolution. Input # 5 is the component input i.e. red/green/blue cable. Just get the correct cable and match colors from cable box to TV this will allow the TV to display 1080i resolution ( only one this TV supports ). FYI you will also have to connect the red and white cables to the appropriate inputs to get any sound because red/green/blue connectors are just for video display not sound. Once your connected you'll be able to access video # 5 be sure to set your cable box to 1080i resolution also. I hope this helps later J.
Dec 02, 2008 | Sony KP-53HS10 TV
How do i get my resolution up to 1080i?
If your cable box is not HD you wont get resolution of 1080.
Mar 21, 2008 | Televison & Video
Display to big with PS3
All CRT RPTVs have overscan, and some sources bring this out more than others.
It can always be cured to at least be able to see the needed parts of the pic, but hoses your picture beyond belief, and correcting that takes time, experience, patience and expertise.
I do overscan reduction on all CRT RPTVs as part of what my calibrations offer, but charge extra to do so.
Mr Bob
Feb 02, 2008 | Philips 60PP9352 60" Rear Projection...
Using Hitachi's 53SDX89BA High-def settings w/ HD-DVD
look at these see if this helps
Most HDTVs cannot properly stretch incoming HD signals, however, if the programme is true HD, you should not much of the image off-screen - most new HDTVs have about 2% overscan and the tickers should be on screen when watched in the appropriate stretch mode.
See: and
Dec 29, 2007 | Hitachi 50UX57B 50" Rear Projection...
Toshiba 57H81 57" Rear Projection Television Logo
63 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
