Question about Toshiba 57H81 57" Rear Projection Television
DIstorted picture for 480p input only
I've seen other postings about distorted pictures, and mine is similar, but it only happens when I'm using 480p input. Whether or not the TV has been on, changing from another input source or a 1080i input source to a 480p input source gives me a distorted picture for about 15-20 minutes.
Thanks for any assistance!
    Champion:
  • 206 Answers
Many set have two differant convergance settings one for 480 and one for1080 this is because when it changes mode the set runns a differant frequencys, what may have happened is you have a cold solder joint somewhere that takes this fifteen minutes to corect itself, might want to start by resoldering the convergance and high voltage curcuits
Posted on Feb 13, 2008
Why is 32d3005 television picture being distorted?
Check all the input connections for tight connection. If found Ok, check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
A defective tuner too can make picture to get distorted.
Aug 08, 2014 | Televison & Video
Distorted picture with wavy lines..
SOUNDS LIKE A CAPACITOR GOING DOWN ON BOARD OPEN BK LOOK FOR BULGING HEADS
Sep 28, 2017 | Sony Grand WEGA KF60WE610 60" Rear...
I have an M520 that used to take great pictures - now lately the picture is distorted and seems to be all grainy/green. I've tried each of the options, resolutions, brightness controls, etc. Sometimes...
QUESTION:::::::::: I have an M520 that used to take great pictures - now lately the picture is distorted and seems to be all grainy/green. I\'ve tried each of the options, resolutions, brightness controls, etc. Sometimes (not every time) after I make a change to the brightness or resolution or white balance setting the picture goes back to normal - but not everytime. Most of the time it\'s just unusable because it\'s so distorted... almost like it\'s over exposed? I\'ve literally checked every setting available to no avail. I want to say it started happening after doing a firmware upgrade. Anyone else having that problem?
answer: i never knew the answer in exam also i cheated fron s 10's boy, the invigilator scolded me but i drank dew ans said daar kay aagey jit hay and continued my cheating program.
so u also cheat the solution of ur desk partener OR buy NOKIA 1100 its perfect 4u ********!!
Nov 11, 2010 | Samsung SPH-m520 Cell Phone
Distorted picture.
Is the menu text clear on the screen, when it's focused correctly. Or is that also distorted.
If the menu text is OK then the picture signal is dodgy. could be due to a bad earth lead on the video cable.
Is it distorted on all signal inputs
Oct 30, 2009 | Panasonic PT-LB20U Multimedia Projector
Sony DSC-t33 lcd monitor is distorted.Pictures
Hi!
It's a faulty CCD imager - a very common problem with the T33 - the imager has to be replaced. You can buy it from http://myworld.ebay.co.uk/toms.rammsteins and replace the CCD yourself (ask seller the instructions).
Tom
Oct 10, 2009 | Sony Cyber-Shot DSC-T33 Digital Camera
DLP Colors Are Off - Picture Is Mostly Blue and Yellow
Sounds like you've lost your red video signal (chroma) somewhere along the line. This tv has a 3 board video path. Analog main pcb --->Digital main pcb --->DMD pcb. The analog has all your inputs on it, except DVI and RGB which go straight into the digital board. The digital scales (upconverts) the signal to HD (1080 or native) and sends it to the DMD or light engine. See which inputs are distorted. If only DVI is clean then you problem is the analog board. If you menu and everything is distorted then suspect the DMD board. If you run component or DVI through the resolutions (480i, 480p, 720p, 1080i) you can get an idea between the digital board and dmd. The menu is generated on the digital board. Somewhere red is getting lost.
Dec 08, 2008 | Samsung HLN5065W 50" Rear Projection...
Can't see picture
Is the onscreen menu just as distorted and are the lines across it or behind it? The pop you heard may have been a capacitor and since the TV is still powering on, it's the probably the video controller board that is on it's way out. If the onscreen menu looks fine, you maybe having a problem with the input board only so try a DVD that uses a different input and if it's poor, I would say the TV needs to have the input/output board service. If the OSD is distorted as well then it's definitely the video controller board and service is likely required.
Oct 15, 2008 | LG 42PX4DR 42 in. Plasma TV
Picture distortion
I have the same or similar problem.
Only HD1 and 2 inputs work correctly.
Jul 31, 2008 | Toshiba 50H71 50" Rear Projection...
Distorted picture on RCA LCD TV
your set has convergence problems i dont have the answer yet ,i do know that convergence broad is not what is causing this! I have one in my shop now with same problem as soon as i find out problem i will post it !!!!!
Jan 09, 2008 | RCA HD52W59 HDTV Projection Television
Picture distorted
Hello buddylaw,
Can you post a picture of the TV screen with the problem? It will help in the diagnoses. It looks like you may have a thermal sensitive component causing this issue. But I will have to seen a picture of the screen to properly diagnose this problem as to the possible section that may be causing this problem.
Thank you.
Shuttle83
Sep 10, 2007 | Sony KV-36XBR450 36" TV
Toshiba 57H81 57" Rear Projection Television Logo
66 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
