Question about Samsung HLR5067WX 50" Rear Projection HDTV
My 5067 freezes randomly and often has green lines or blocks in the picture. Sound comes and goes along with the image. This is only in TV mode, picture is fine with other sources. I can usually fix this temporarily by unplugging the tv and plugging back in until it works correctly, but it is totally random and REALLY annoying. Also, problem #2 - even with no freezes or green lines, the digital HD channels with a dash one ending (5-1) seem to work much better than standard cable channels. Often, if I try flipping to a standard channel like 39, I get nothing and my tv starts acting irradically. At other times, they work just fine. Interestingly, they always seem to have a perfect image if they are just in the Picture-in-Picture and not the main channel. I am using a coax straight to the tv with no box or other instrument in between. Once any of these issues occur, my tv starts acting completely irradically (can't change channel, adjust volume, use remote...I just have to unplug it and try again). Other tv's work just fine from this outlet. Any and all of your help is much MUCH APPRECIATED!
    New Friend:
I have HLN 5067wx after replacing the color wheel and inserting new lamp There is sound withou the grinding but absolutely no picture; What is going on?
Posted on Nov 16, 2009
SOURCE:
Picture goes black with gray fuzzy lines ~ 1/2" apart horizontal.
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Take it to a repair shop.
Apr 05, 2014 | Sanyo DP50749 50 in. Plasma TV
SONY TV PICTURE TURN GREEN WITHOUT RETRACE
Picture goes to high green with retrace lines that shows picture tube is defective and requires replacement.
Usually in above symptom, TV goes to standby mode and standby light blinks when green raster problem occurred.
New TV is better option because picture tube of KV-34XBR960 would not be available any more.
Thanks.
Aug 14, 2009 | Sony Televison & Video
Green line running vertically along the edge of picture
If its a LCD projection TV (such as Sony Wega, Hitachi, Epson, Philips, and some Panasonic, some Mitsubishi), and the green image is in the whole screen or just one part as a blob or a line. Is most probably that one of your LCD Color Filters is damaged (burned out or starting to get busted), I don’t know if you can just replace the color filter, I believe you need to change the whole light engine system or the optical block. There are some places around, I found some on ebay but you should definitely try on discountdashmerchantdotcom their price range $260.00 - $330.00
Jun 25, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Screen goes black
not worth fixing,techs charge at least 65.00 $ an hour not including trip charge.no easy fix. you can get new lcd flat panels for under 500$ now. especially at best buy,ther giving them away
May 19, 2009 | Sony KV-32XBR450 32" TV
Rear projection tv picture problem
Sounds like a tuner or Video output problem. What make and model set do you have.
Jan 09, 2008 | Televison & Video
Samsung HLR5067WX 50" Rear Projection HDTV Logo
179 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
