Question about Philips Standard 105S Monitor
Contrast Menu appears after switch On
After switch ON the contrast menu appears on the screen. It goes on increasing to 100 %. If "<" reduced with this button again it reappears. In the Menu screen the menu goes on shifting to the next tab automaticaly. If we exit with Exit button again the contrast window reappers. All the switches and the resistors are good and now the technician suggests to replace the main board...Please suggest.
Contrast Menu appears after switch...
Posted on Jun 18, 2009
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
The contrast of my calculation is low
Turn calculator ON.
Press the Menu button.
Use arrows to get to the SYSTEM icon.
Press Left Arrow to decrease contrast or Right Arrow to increase contrast (darken the screen.
If the screen is not legible (too light or too dark) you use ALPHA E to access the System menu.
Jan 31, 2012 | Casio Algebra FX 2.0 Calculator
Unable to adjust the settings for brightness and contrast .
To adjust the display settings:
1. Press the flywheel control. The main menu appears.
The current display settings appear across the top of the main menu.
2. Rotate the flywheel to highlight an option. The name of the
highlighted option appears in the center of the menu.
3. Press the flywheel control to select the highlighted option, then
rotate the flywheel to adjust it.
Some options can only be enabled or disabled. There are also some
options that contain additional menus.
4. Repeat Steps 2 and 3 until you have made all your changes.
5. Rotate the flywheel control until Exit is highlighted, then press
it to exit the OSD control system.
OSD OPTIONS:
Contrast increases or decreases display image contrast.
Brightness increases or decreases display image brightness.
Horizontal Size increases or decreases the width of the display image.
Horizontal Position moves display image to the left or right side of
the screen.
Vertical Size increases or decreases the height of the display image.
Vertical Position moves display image to the top or bottom of the
screen,
Pincushion curves the sides of the display image inward or outward.
Trapezoid increases or decreases the trapezoid distortion of the
display image.
Degauss removes magnetic discoloration from the display image.
Recall returns most options to the original factory default settings
if the monitor is currently using a preset video mode. (See the “Video
modes” section in this guide for information about the factory preset
modes.)
Advanced Option opens the Advanced Option menu. Color opens the Color
Manager menu.
Language changes the display language for the OSD control system.
User displays information about the monitor’s preset modes.
OSD Manager moves the OSD control window on the screen.
Exit closes OSD control system.
Jun 21, 2010 | Gateway EV 910 19" CRT Monitor
Contrast menu is appearing on the screen,inspite of pressing exit button.if i even low down the contrast.it will automatically increases to 100%.all the other menu is appearing occasionally and changing...
If you are using a Dell's LCD, most probably the soft button of the menu panel need to be replaced. I recommend you try to resolder back the soft button 1st, sometimes it's just having a dry joint after years of usage, if you are familiar with electronic component soldering.
Jan 08, 2009 | Computers & Internet
Contrast 100 window keeps appearing on screen
try to use the monitor menu button and do a factory reset, it should take care. try to unplug the monitor cable from the tower you will get monitor self test if its good then the problem is not with the monitor it should be the problem with the tower.
Dec 07, 2008 | Dell Dimension 2400 PC Desktop
Monitor problem
It seems that ur control panel on the monitor having some problem...U need to take it to service center....
Dec 02, 2008 | Computers & Internet
Contrast of jvc tv to low
Basic settings are frequently only accessible via the remote Menu function. If you do have 'brightness' as a set-top adjustment, you can improve the contrast by slightly reducing that setting.
Nov 23, 2008 | JVC Televison & Video
Contrast automatically increases to 100%
yes! The same problem in my monitor. The contrast of my PC monitor increases automatically to 100%.If I try to reduce it,it increases again.
Oct 19, 2008 | IBM E54 15" CRT Monitor
Philips Standard 105S Monitor Logo
610 people viewed this question
Top Philips Computers & Internet Experts
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
