Question about Compaq Presario 5000 PC Desktop
My windows search is not working
I work on XP and the system's search option is not working... the dog is appearing but the search options are not displayed... though avg antivirus is there..
  • 45 Answers
Doug Knox has a possible solution under XP Tips, look for Fix Windows XP Search (error) and try the vbs fix
http://www.dougknox.com/
Posted on Jan 02, 2008
Turn off Work Offline in XP
  1. Start Internet Explorer.
  2. On the File menu, determine whether the Work Offline option is enabled.
    Note If this option is enabled, a check mark appears next to Work Offline.
    If this option is enabled, go to step 3.
  3. On the Tools menu, click Internet Options.
  4. In the Internet Options dialog box, click the Connections tab.
  5. Make sure that the Never dial a connection option is selected.
  6. Click the Advanced tab.
  7. Under Browsing, click to clear the Enable offline items to be synchronized on a schedule check box, and then click OK.
Jul 29, 2014 | Microsoft Windows XP Home Edition
It is not starting up
Good day. I suggest for you to reinstall windows and use the repair options. Usually software encounter errors or some files might get corrupted causing your computer not to boot up properly. The repair option in Windows XP will help you to fix those issue. here are the steps to follow:
1. Rule out hardware issues. Windows Repair will only fix software problems. Hardware issues can also cause boot problems (i.e. bad hard drive, memory, CPU, or power supply).
2. Backup. It's always a good idea to backup your important data before making changes to Windows XP. Relax, if you follow these instructions your data will be perfectly safe.
3. Boot from your Windows XP CD. Insert the Windows XP CD into your computer's CD-ROM or DVD-ROM drive, and then restart your computer. When the "Press any key to boot from CD" message appears on the screen, press a key to start your computer from the Windows XP CD.
4. A blue screen will appear and begin loading Windows XP Setup from the CD.
5. When completed loading files, you will be presented with the following "Windows Setup" screen, and your first option. Select "To set up Windows XP now, press ENTER". DO NOT select Recovery Console.
6. Then press F8 to continue
7. Next, Windows Setup will find existing Windows XP installations. You will be asked to repair an existing XP installation, or install a fresh copy of Windows XP.
8. Then just choose repair option to repair your Windows Xp
9 Then it should work. If iin any case that will not solve the issue, you might try to install fresh copy on Windows Xp
Hope this information will help you resolve your issue. Have a great day.
May 24, 2011 | Microsoft Windows XP Home Edition
My ksuser dll for windows xp profesional
Just boot from the xp professional cd and run the recovery console.
Download the operating system from this link: http://www.microsoft.com/downloads/en/details.aspx?FamilyID=2fcde6ce-b5fb-4488-8c50-fe22559d164e&displaylang=en
or
if you have it, install it using the procedure below:Boot From the Windows XP CD
  • You must boot from your XP . Please make sure it is the same version of Windows that is currently installed on your computer (ex. XP Home cannot repair XP Professional). Place the CD in your CDROM and start your computer. Newer versions will work as well (ie. Windows XP Pro SP2 CD will work on an older WinXP Pro SP1 installation)
    you will be asked to press any key to boot from CD, so do just that.
    Step 3: System repair steps
  • A blue screen will appear and will begin loading XP setup from the CD.
    simply let the CD load without pressing F6.
    Once completed, you will be confronted with "Windows Setup". You will be asked to setup up Windows, or repair Windows with the recovery console. Choose the FIRST option, NOT recovery console.
Choose F8 to continue.
  • Next, Windows Setup will find existing Windows XP installations. You will be asked to repair an existing XP installation or install a fresh copy of Windows XP.
    If no installations are found, then you will not be given the option to repair. This may happen if the data or partition on your drive is too corrupted.
That should be it. Windows XP will appear to be installing itself for the first time, but it will retain all of your data and settings. Just follow the prompts
Apr 19, 2011 | Microsoft Windows XP Professional
I've upgraded my computer n hv windows 7 n my scanner Umax Astra 5600 does not operate on the new computer. I need yr help in getting the driver for windows 7 for my Umax Astra 5600.
most old scanner are not working with windows 7 and also 64bit of win 7
VueScan is bringing them to life ;)
http://www.hamrick.com/
Feb 28, 2011 | Computers & Internet
I'm running windows xp and my wife was using the computer and all of a sudden all of the icons on the dektop changed in appearance. When we now click on any icon we get the message if we want to either...
On most computers you will have the option of restoring windows on one of the F key options, when it's booting up. The trick is to get to the Repair Computer option screen (it's different on different computers but does the same thing). If you can get the Restore Option before windows sets up, you'll fix this problem. On my Toshiba F2 and F12 are reserved for options, but I also get other options pressing F4 through F8 as it's booting- not sure which key works, so I hit all of them. Keep working that angle, and I'm sure you'll get it working again. Good luck, and hope this helps.
Jul 30, 2010 | Computers & Internet
Can't boot windows xp
  1. I believe your talking about Windows XP
  1. Restart your computer and start pressing the F8 key on your keyboard.
  2. Select an option when the Windows Advanced Options menu appears, and then press ENTER.
  3. When the Boot menu appears again, and the words "Safe Mode" appear in blue at the bottom.
  4. try that and see it works.
  5. if so reboot and then use the last known configuration option.
Nov 30, 2009 | Acer Aspire One Netbook 8.9" Notebook
After booting process done. Screen goes blank and Keyboard not working only Mouse cursor is dispaly and working on the blank screen in My acer Laptop.
Try booting the system to Safe mode.
To boot to safe mode:
Restart the computer. As soon as the BIOS has finished loading, F8 key on your keyboard. When Windows Options menu appears, scroll to select the Safe mode menu item, and then press Enter.
Select "Last known good configuration" then press Enter.
If that doesn't work reboot again and keep tapping on F8 to Safe Mode and instead of selecting "last known good configuration" select "Repair Your Computer"
Or you can try this:
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
  1. Place your Windows XP set up disk in your CD drive.
  2. Turn off your computer and change your BOOT order to boot from CDs first.
  3. Turn your computer back on.
  4. Press any key on your keyboard when it asks you to.
  5. Press enter when you see a blue screen, one of the options should say, "To setup Windows XP now, press ENTER.".
  6. Press enter to start the windows set up.
  7. Accept the Licence and Agreement and confirm that the setup is searching for current versions on XP.
  8. Press "R" when the set up has found your current version of XP.
  9. Notice that the Set up is deleting all your windows xp files and replacing them. (This will not cause loss of data)
Jan 11, 2009 | Acer Aspire 5610 Notebook
Need bjc50 printer driver to work with windows XP bjc50
Although a driver for your printer is not available through Canon, the printer are fully compatible with the Windows XP operating system. The printer driver is built into the Windows XP operating system and can be installed using the Add a Printer option in the control panel.
This option is also available through the Printers and other Hardware option in Windows XP.
Jul 30, 2008 | Office Equipment & Supplies
Corrupted Search
Turn the dog off and I assume ur talking about the search from ur start menu???
The options should be a menu to the left.
Mar 03, 2008 | Microsoft Windows XP Professional With...
Compaq Presario 5000 PC Desktop Logo
54 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
