Question about Nikon Super Coolscan 4000 ED Film Scanner (35 mm)
USB cable from scanner to new Dell Optiplex 755
The cable that came with the Nikon Coolscan 4000 that goes into Dell will not fit into into the USB port because of the design.
What are my options to be able to use the scaner ?
Thank you, Norm
  • 4 Answers
If you look carefully at the cable, you will notice it is a firewire cable (IEEE1394), not USB. You will need a firewire interface on your computer to use the Nikon scanner. It will not work with a USB port.
Posted on Feb 04, 2008
Tip
Nikon Super Coolscan Jam Solution Do you find your older slides, cardboard...
Do you find your older slides, cardboard slides, or irregular slides jam in the Nikon SF-210 Slide Feeder for your Nikon CoolScan 4000?
Try this solution:
Take a AAA battery and place it in rear, left side of the slide feeding tray as pictured below:
The slides will fan out nicely, and your Nikon CoolScan will no longer try to load more than one at a time. Instead it will load them one at a time, 50 per tray, and you can actually walk away from it and let it do its job, just the way you intended to when you bought the SF-210 slide feeder attachment!
I hope that helps.
on Apr 09, 2010 | Nikon Super Coolscan 4000 ED Film Scanner...
Recently upgraded from Windows Vista to Windows 7. Where can I get correct drivers to run with my Nikon Super Coolscan slide scanner LS-4000 ED model. I have Nikon Scan 3.0 twain software. Stu Milligan
Hello there.
This will help you if you have 64-bit Windows 7, because officially, there is not windows 7 64 bit driver.
Just read and do everything.
http://www.earthboundlight.com/phototips/coolscan-vista-64.html
Otherwise, if you have windows 7 32bit click here:
link
To check bits, go right click on My Computer, Properties, and you will see it.
Sincerely,
Steve TM
May 28, 2011 | Nikon Super Coolscan 4000 ED Film Scanner...
My Nikon CoolScan 4000 is not working properly. All images come with a green shade
I had the same problem with coolscan LS 50 ed, but the chromatic dominant was blue instead. What you have to do is to perform a p.o.s.t. procedure: 1) swith off the scanner and unplug it from the PC; 2) switch off the PC; 3) remove the film-holder from the scanner; 4) switch on the scanner; 6) plug it back to the PC; 7) switch on the PC; 8) insert the slide/film holder. It should work now...
Oct 02, 2010 | Nikon Super Coolscan 4000 ED Film Scanner...
Need a new driver for coolscan 4000 ED for Vista.
You can download the Vista Driver at this link: 4.0.3 full version - Vista only
If this information was helpful, please give me a big thumbs up when you rate my answer.
Feb 03, 2010 | Nikon Super Coolscan 4000 ED Film Scanner...
Where can I find the Nikon CoolScan 4000 Scanner Installer?
Please follow the below link and download the installer for your CoolScan 4000
http://support.nikontech.com/app/answers/detail/a_id/16453/session/L3NpZC9pODRBbzJNag%3D%3D/p/25%2C27/c/185/r_id/116678/sno/1
Click on "I agree - begin download" and the download will start.
Install it and enjoy.
Cheers
Nov 03, 2009 | Nikon Coolscan IV ED Film Scanner
I believe my coolscan 4000 may have or is failing - can you help me determine if it is a hardware or software (driver) problem?
I contacted Nikon Tech Support and with them determined that the scanner failed POST and needed hardware repair.
Oct 06, 2009 | Nikon Super Coolscan 4000 ED Film Scanner...
Nikon Super Coolscan 4000 ED Film Scanner (35 mm) Logo
291 people viewed this question
Top Nikon Office Equipment & Supplies Experts
Jerry Greenberg
Jerry Greenberg
David Darrow
Level 1 Expert
Tanvi Thakur
Are you a Nikon Office Equipment and Supply Expert? Answer questions, earn points and help others
