Kenmore 62602 Electric Dryer
Problem for Kenmore 62602 Electric Dryer
Kenmore dryer will not git hot HEATING ELEMENTS is
By roberttay80 on Oct 30, 2009
kenmore dryer will not git hot HEATING ELEMENTS is good and thermostat is good
Best Solution
posted on Oct 30, 2009
Very Helpful)
mgprice
Rank: Guru  Kenmore Expert
Rating: 96%, 431 votes
Hello, Ok if you have checked the heater, hi-limit, thermal fuse and thermostat and they are all good your problem is going to be with the centrifugal switch. This is built into the motor. To check this pull the wire harness off the motor and where you see the 2 big wires going into the plug make a jumper wire with 2 male spades and some wire. Jump this wires and then run a cycle for a few seconds. if the heater comes on you have found your problem. This will require you replace the motor. Hope this helps. Mike
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #2
Helpful)
jballiett000
Rank: Guru
Rating: 94%, 15 votes
Most models of electric dryers there are several safeties in place before you get to the element. Power comes from the timer and goes to a snap disc thermal cut out, a thermal fuse, through the element, back through a thermostat and a high limit, and even sometimes going through a centrifugal switch on the motor. This switch will not allow the element to come on unless the motor is running. If any of the components from the timer all the way through the element and back to the original power source are broken, you will have no heat. You can test most of them with a test light or a multimeter on continuity test.
Hope this helps
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #3
posted on Nov 04, 2009
Not Rated)
salde386
Rank: Guru  Kenmore Washers & Dryers  Expert
Rating: 94%, 45 votes
when you read out the heater and t-stats did you disconnect one of the wires if not it will show continuityalso check the heater again and make sure none of the coils are touching metal casing
Comments:
Nov 07, 2009
- could also have a broken wire somewhere
Nov 15, 2009
- also read out the thermal fuse located on top of blower wheel housing
Was this helpful?
Yes
No
Popular Solutions for Kenmore 62602 Electric Dryer
Questions and Unsolved Problems for Kenmore 62602 Electric Dryer
Do you recommend Kenmore 62602 Electric Dryer?
Answer
Answer
i turn the dryer on and then hold the button down so i can look inside and whatch the heat elements... (More)
Answer
model 110.66912692 will not start....can hear timer, but when i push start nothing
Answer
Kenmore 90 series gas dryer won't start. Model #11072912100. Light comes on inside. What should I... (More)
Answer
gas dryer and won't heat up worked just fine and boom no heat
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Kenmore 62602 Electric Dryer:
Top Dryer Experts
Rank: Guru Guru
Solutions: 14851
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Dryer Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
