Hotpoint 24 in. HDA3400G Built-in Dishwasher
Problem for Hotpoint 24 in. HDA3400G Built-in Dishwasher
When the water cycle is running there is a white
By versatile353 on Oct 30, 2009
When the water cycle is running there is a white plug by the water inlet that is leaking. When the dishwasher is not in the water cycle it does not leak. When the dishwasher is stopped in the middle of the wash cycle and water in in the bottom of the pan it does not leak. It only leaks when the water is running.
Best Solution
posted on Oct 30, 2009
Very Helpful)
jyappl
Rank: Guru
Rating: 87%, 23 votes
crack in water inlet valve or a pin hole in the hose going from the valve to side of tub spraying water where you see it. You have a holein someting. You need to trace it back to its sourse. When you say "water is running"im guessing thats when its filling with water not just washing.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Hotpoint 24 in. HDA3400G
Questions and Unsolved Problems for Hotpoint 24 in. HDA3400G
Do you recommend Hotpoint 24 in. HDA3400G Built-in Dishwasher?
Answer
Answer
clip broken off detergent loader container, container will not clip shut.
Answer
how do i drain the macerator connected to my toilet, it has broken and needs to be changed. this... (More)
Answer
the solenoid for the waist water dump valve has over heated and melted twice. valve not the problem.... (More)
Answer
My dishwasher does not drain. I've pulled off the main top screen. What next? How do I pull off the... (More)
Answer
Machine went through first light wash and then stops on the second light(spray) and beeps and won't... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Hotpoint 24 in. HDA3400G...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1581
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
