Question about Black & Decker B2000 Bread Maker
Breadmaker B2300 won't even turn on at all
My Breadmaker will not turn on at all. I plug it in and nothing happens... I made one loaf with it and that's it. I went to make another yesterday, followed all of the directions and nadda, it won't even turn on.
  • Anonymous Jan 05, 2008
    put all ingredients in,pressed #4 for lg w wheat loaf. Dont have book. PRESSED
  • SyD777 Feb 19, 2008
    I got a bread maker as a gift,  it is sitting in the kitchen at this moment counting down but there is nothing happening,  It counts down a few minutes an then resets to the start time.  ????? My other bread maker started mixing when I hit start.
    Model b2300
  • 26 Answers
Sound like your heating element got toasted. You one of two options, try repair it yourself or send it to service center to get it repair. If you decide to repair it yourself just visit your nearest service center, and take the following information; model # , serial #, and brand. There you will get all the information you need to get it up and running again.
Good luck,
Spur21
Posted on Jan 07, 2008
6ya staff
SOURCE:
Breadmaker will not startup
which program are you selecting? Is it whole wheat?
Jan 23, 2013 | West Bend WestBend Hi-Rise Breadmaker
Recipes for b&d breadmaker model 2300
Knowing your breadmaker's loaf capacity will enable you to find recipes of any variety on the Internet for free.
It will also keep you from adding too much ingredients which could cause dough to over-rise and spill onto the heating element.
Remove your bread pan from your breadmaker. Using a one-cup 8-fluid-ounce liquid measure, fill your bread pan with water. As you do, count the number of cups it takes to fill your bread pan to the very rim.
Generally speaking...
If your bread pan holds 7 & 10 cups to the rim then you have a 1.0 lb or 500 g loaf pan
10 & 11 cups to fill = 1.5 lb (700 g) loaf pan
11 & 13 cups to fill = 2.0 lb (900 g) loaf pan
13 & 15 cups to fill = 2.5 lb (1250 g) loaf pan
15 & 17 cups to fill = 3.0 lb (1350 g) loaf pan
A bread recipe for use in a 1.0 lb (500 g) breadmaker should never exceed 2-1/4 total cups of flour.
1.5 lb (700 g) = 3-1/4 c
2.0 lb (900 g) = 4-1/4 c
2.5 lb (1250 g) = 5-1/4 c
3.0 lb (1300 g) = 6-1/4 c
Warning: When testing a new bread recipe it is always best that you not leave your breadmaker unattended. Stay close by to monitor its progress from time to time.
Did this answer help? I hope so. Please rate it as soon as you can. Thank you.
Jun 26, 2011 | Black & Decker B2300 Bread Machine
I have a convection bread maker. I made one loaf of bread tonight and i unplugged the machine. 30 minutes later, I tried to make a second loaf ant the menu select wouldn't work but the start and mix in...
Cuisinart has many different bread machine models. Next time you ask a question, please include a model number. Thank you.
Here's my generic best advice for you dear:
Addressing Power-up/Start-up Issues:
1. Unplug the breadmaker.
2. Confirm the power source you're accessing is live using a blender, toaster, etc.
3. Plug the breadmaker in.
4. Confirm the breadmaker is receiving power:
    1. Some models have a built-in off/on toggle power switch. Turn it to the ON position.
    2. Some models confirm power by making and audible tone when plugged in.
    3. Some models have a colored light and/or a lighted display screen that lights up.
    4. Some models require you press and hold the Select button down until the unit powers up.
    5. Some models require you press and hold the Start button down until the unit powers up.
    6. Some models require you select a mode first by pressing the Select button.
    7. Some models require you press and hold the Stop button down until the unit powers up.
Were you able to confirm that your breadmaker is receiving power?
No. Sorry to hear that. Attempt to have the breadmaker serviced by a small appliance repair facility or simply discard it.
Yes, Fantastic! Now reboot the breadmaker's electronics by pressing and holding down the Stop button down until you receive a visible and/or audible confirmation, usually within 1 to 5 seconds. Note: Some models require you press and hold the Start button. Others require you press and hold the Select button.
Often the + and - Timer Delay buttons are pressed by mistake, delaying Start by up to 12 hours. If you suspect the Timer Delay feature has been engaged accidentally, you'll need to reboot the breadmaker's electronics.
All breadmaker use a belt and pulley system. If your breadmaker powers-up but the mixer won't turn when it's supposed to, your belt is probably broken. You'll need to disassemble the breadmaker to visually confirm.
Jun 13, 2011 | Cuisinart Kitchen Appliances - Others
I received my breadmaker Christmas 2009. I have always used the basic setting but decided to make wheat bread. The recipe calls for a different setting. After I plugged it in, nothing happened; for...
Yes, many machines warm up a little when you choose the wheat setting, also if your manual shows the cycle times for the various programs you will probably notice a different Knead time (more) vs. the basic program and that is because whole wheat flour lacks enough gluten to make a nice, large, soft loaf, so to compensate it has a longer knead. Even with that though your whole wheat loaves are probably going to be shorter than a 100 whole wheat loaf.
Many bakers ( me included) add purchased wheat gluten and add that to the flour, (be sure to remove and equal amount of w. wheat flour from the recipe if you do this) to get a softer, higher, better texture loaf.
Feb 01, 2011 | Toastmaster Kitchen Appliances - Others
Needing the recipe for white 3lb sandwich loaf for the all in one model B2300. Lost the manual and there is nothing online
Hi Lyndseycoone:
Here is the recipe from the manual
3 cups of water (80 to 90 F)
3 tbsp butter or margarine, cut into pieces
1 tsp salt
3 tbsp dry milk powder
4 tbsp sugar
5 1/2 cups bread flour
1 1/4 tsp active dry or bread machine yeast
1. Measure ingredients into bread pan in the order listed
2. Insert bread pan into unit, close lid. Plug unit into wall outlet
3. Select Sandwich setting and appropriate loaf size (3 lb)
4. Press start button
5. The Complete Signal will sound when bread is done.
6. Using pot holders remove bread pan from the unit and carefully remove bread from pan and turn right side up. (Kneading blade may remain in bread. Remove blade when bread is cooled.
7. Allow bread to cool on wire rack until ready to serve at least 20 minutes.
Hope this helps...
Darlene
Nov 06, 2010 | Black & Decker B2300 Bread Machine
Kneading blade cooks into the loaf
Hi Jessica,
As I read the manual, under the Care & Cleaning section,
"2. If the kneading blades remain in the bread pan, grip the kneading blade and
pull straight up to remove......"
Based on the diagrams and instructions, I don't think you're supposed to pull the blades before baking...why do you want them out? Cosmetics?
If I can be of further assistance, let me know. If this solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Jan 08, 2009 | Black & Decker B2300 Bread Machine
B2300 breadmaker
I had the same problem and what you need to do is hold the start button down for 3 seconds and that will clear the default setting (1 3:30). Then select the settings you need starting with the program setting for your recipe (i.e. #4 for sandwich bread). Bear in mind that you may not be able to select your crust light/dark option for some recipes, but will be able to select the loaf size. I assume this is because the recipe program (i.e. #4 for sandwich loaf) is already prescribed in the setting. When you have all of your selections then press your start button, but don't hold it down for longer than a second because it will clear everything and you will have to start again from step 1. Good luck!
Dec 17, 2008 | Black & Decker B2300 Bread Machine
Breadmaker Won't Start
I had the same problem. Check the delay start button even though it doesn't tell you to. To get my machine to work the first time I used Menu #3 (which does not have a delay start) and it worked. Then I tried to use the dough cycle and it wouldn't go either, so I unplugged the machine, plugged it back in, went to Menu # 3 first to see the time (which was 1:50) then I checked the delay time to make sure it was also set at 1:50. Mine was not (it said 2:00) so I moved it down to 1:50 and it started 15 minutes later. I really don't like this 15 minute delay on this machine. I am going to try regular bread later and I will make sure that the delay time is the same as the time given for completing the loaf ( ie make sure it says 3:30 NOT 13:30. I hope this works.
Feb 09, 2008 | Black & Decker B2000 Bread Maker
I have a problem with uneven shaped loaves
The paddles fit two ways, so what you must do is have them facing opposite ways, then they fight with each other and elongate the loaf
Dec 30, 2006 | Black & Decker B2000 Bread Maker
Kitchen Appliances - Others Logo
155 people viewed this question
Top Black & Decker Kitchen Appliances - Others Experts
Irene Tulloch
Gerry Harvey
Gerry Harvey
Are you a Black & Decker Kitchen Appliances - Other Expert? Answer questions, earn points and help others
