Whirlpool LGB6300 Gas Dryer
Problem for Whirlpool LGB6300 Gas Dryer
I have a whirlpool gold ultimate II electric dryer
By robndugan on Oct 30, 2009
i have a whirlpool gold ultimate II electric dryer and would like to know how to remove the front and side panels to remove the lint on the inside.
Solution #1
posted on Oct 30, 2009
Not Rated)
mgprice
Rank: Guru  Whirlpool Expert
Rating: 96%, 463 votes
Hello, If the lint filter is under the flap at the top lift the flap up and remove the 2 screws. Slide a putty knife under the lip between the top and the front panel about 3 inches from each end and push in the clips holding the top down. Lift the top up and look inside the machine either side and remove the 2 screws you see. now lift the front panel off. you now have access to inside the dryer :) Hope this helps! Mike
Was this helpful?
Yes
No
Popular Solutions for Whirlpool LGB6300 Gas Dryer
Questions and Unsolved Problems for Whirlpool LGB6300 Gas Dryer
Do you recommend Whirlpool LGB6300 Gas Dryer?
Answer
Answer
the burner comes on for 5 seconds then go's back out .then off for about 60 seconds .then starts... (More)
Answer
makes a large clanking noise during the drying cycle, it will go on the entire 70 min cycle..is the... (More)
Answer
The drum spins and gas is turned on. Took off the back panel and the manifold from burner to drum,... (More)
Answer
I have a whirlpool 3622eqt gas dryer that will start and blow hot air but after a few minutes will... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dryers Experts
Top Washer & Dryer Repairmen
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
