Amana ABB1927DE Bottom Freezer Refrigerator
Problem for Amana ABB1927DE Bottom Freezer Refrigerator
Evap coils frost up for about the first 4 inches
By ball7499 on Oct 30, 2009
evap coils frost up for about the first 4 inches then no frost any further
Best Solution
posted on Oct 30, 2009
Very Helpful)
jyappl
Rank: Guru
Rating: 87%, 23 votes
Your mostlikely low on freon. You have a leak in system that has to be repaired. Its a big buck repair.
Other possibility is a bad compressor or a restricition in the sealed system. Also a big repair. If frig is under 5 yrs sealed system should be under warrenty.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Very Helpful)
Nico-Fixus
Rank: Wiz
Rating: 90%, 15 votes
This could be a low capacity compressor issue (It can pump the coolant down far enough to make it cold again. Or perhaps your coils in the back or under the machine are dirty and not able to dissipate heat. The last thing is that it could be low on coolant. If this is your main fridge, call a tech to take pressure readings to see if the coolant is too high or too low. Clean the coils in the meantime and see if anything changes.
Was this helpful?
Yes
No
Popular Solutions for Amana ABB1927DE Bottom Freezer
Questions and Unsolved Problems for Amana ABB1927DE Bottom Freezer
Do you recommend Amana ABB1927DE Bottom Freezer Refrigerator?
Answer
Answer
the bottom freeer is blowing air not kool..and liaking water with nothing in it..it 7 yurs old?/f
Answer
frig or freezer wont get get cold after movin it from one house to another now?
Answer
I have an Amana frig with the freezer on the bottm. The frig is working fine but the freezer isn't.... (More)
Answer
Freezer handle has de-attached from door on right side - can it be repaired? I cannot see how you... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Amana ABB1927DE Bottom Freezer...:
Top Refrigerator Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(650) 616-9292
Refrigeration Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
