probably the fuse under the light and button panel has blown, tinker around and find out how to get the panel off and replace the fuse with the exact same type if it is blown
I have a Bosch Nexxt Front load Washer and using your posts was able to fix the E:04 error and clear...
(More)
I have a Bosch Nexxt Front load Washer and using your posts was able to fix the E:04 error and clear the blockage in the front trap. Unfortunately it won't stop leaking now. I double checked I put it back in correctly but no luck. Any ideas on another cause? Thanks, Helen
I have had my 500 plus washer for about a year, and I'm having trouble with it spinning heavy loads....
(More)
I have had my 500 plus washer for about a year, and I'm having trouble with it spinning heavy loads. The user manual says to put small and large items in each load to help with balance. I try to do that, but with big pairs of jeans or work pants or cargo shorts, it sometimes clunks loudly, and not just when it is shifting from one speed to the next. Does it just get louder as it get older, or should I have it looked at?
my Bosch Nexxxt 500 Plus washer when you turn it on gives a E: error no code number after it and the...
(More)
my Bosch Nexxxt 500 Plus washer when you turn it on gives a E: error no code number after it and the washer will not function in any capacity.
