Question about Weather King 10AJA2501AH Air Conditioner
Electric heat strip installation and wiring
Have a nordyne heat pump tryin to hook up heat strips to unit . unit is a q1sa 42 with hme-15 heat strips
  • 80 Answers
YOU NEED #6 WIRE AND A THERMOSTAT THAT WILL SUPPORT 2 STAGE HEAT NEED MORE HELP LET ME KNOW
Posted on Jan 09, 2008
    Problem Solver:
  • 10 Answers
Need to make sure your wire size to the inside unit is large enough to handle the amperage, that you have a two stage heat thermostat.
Posted on Jan 04, 2008
I have a 5-ton Nordyne heat pump. The compressor has quit working. How can I get the emergency heat strips to come on using emergency heat on the thermostat.
Your thermostat should have an emergency heat setting. Putting the thermostat in that position should make the electric heat strips only work and keep the compressor from coming on. If your thermostat doesn't have an emergency heat selection disconnect the compressor outside at the power source. Turn the thermostat 5 degrees Above the Rim temperature the electric heat strips should come on.
Jan 02, 2018 | Heating & Cooling
5 ton goodman package unit not coming on
If you look on the install manual. It says it will work for a heat pump without backup heat. No heat strips.........If you do not have strips the guide says as follows
"PLACE A JUMPER (PIECE OF WIRE) BETWEEN Y AND W IF YOU ARE USING A HEAT PUMP WITHOUT AUXILIARY/BACKUP HEAT." if this dosnt work check the fuse in the air handler you may have blown it if you did not turn the unit off before installing.
Mar 25, 2014 | Goodman Heating & Cooling
Goodman package unit heat strips will not turn on
Put meter probes at in put terminal of the element if you read 220volts that mean your relay is good. if you got it there use amp meter on one leg of that element. You should read some amp draw there but if there is no amp draw it mean the element broke.
Nov 29, 2013 | Goodman Manufacturing Goodman GPH1530M41...
How to hookup Auxiliary heat (and/or use an extra wire at the thermostat)
They don't always use the correct wire colors,if it is labeled w it is for your strip heat,shouldn't hurt to hook it up,most likely they used it for the strip heat,most heat pumps are wired to turn on your strip heat when the heatpump is in defrost mode and it is controlled by the heat pump,you can hook this to the emerg. heat or w2 :)
Mar 08, 2013 | Ruud Heating & Cooling
How to tell if your unit is a heat pump or just air conditioner with electric heat strip
PTH is a heat pump. PTC is an air conditioner only. I don't believe Amana makes electric heat strip-only models based on what I see in their literature. You can just do a google search and look for yourself.
Nov 29, 2011 | Amana PTH123B25AJ Heat Pump Air...
I have a 5 ton goodmsn heat pump it only blows cold air the heat doesnt come on have a new heat strip in it but still blows cod air
Heat pumps require a reversing valve for heat operation on the outdoor section, a control signal to a "O" terminal or orange wire is required for heating and cooling depending on the thermostat and out door unit requirements. The thermostat also has to be heat pump type for the system to operate heat for electric system with heat strip, two stage electric heating.
Jan 31, 2011 | Goodman CKL60AR60 Air Conditioner
I woukd like to have my heat electric, right now its gas and the AC is electric. I have added heat strips to an AC unit before but am not sure if i can with this one. They both one on one thermastat. Am i...
Depending on the unit it might be possible but the 1st thing you have to do is change the wire to your unit probably to # 6 depending on the KVA rating of the heat strips. Your unit because it's gas it is wired only for 20 or 30 amps & most electric strips are 60 amps.
Oct 04, 2010 | Heating & Cooling
Nordyne GB5BM T49K C what heat strips do I need or what KW ?
You need to know how much heat you need (heat loss) and then figure the KW of heat that you need to make that. (3415 BTU's per KW)
Nov 10, 2009 | Heating & Cooling
Intertherm heat pump
FIRST YOUR OUTSIDE UNIT PROVIDES HEAT BY USING A REVERSING VALVE TO CHANGE THE REFRIGERANT FLOW.THERE IS NO HEAT STRIPS OUTSIDE SECOND YOUR EMERGENCY HEAT TURNS ON ELECTRIC ELEMENTS INSIDE YOUR AIRHANDLER UNIT.IT SOUNDS LIKE SOMEONE HAS WIRED YOUR UNIT WRONG OR HAS THE THERMOSTAT SET IMPROPERLY.WHEN THE HEAT PUMP CANNOT SATTISFY THE SETPOINT THE THERMOSTAT IS SUPPOSED TO TURN ON YOUR ELEC. HEAT UNTILL THE LOAD HAS BEEN REACHED AND THE HEAT PUMP CAN CONTINUE TO MAINTAIN IT.
Nov 28, 2007 | Heating & Cooling
Weather King 10AJA2501AH Air Conditioner Logo
2,180 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
