Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator
Problem for Maytag MFI2568AES Stainless Steel Bottom Freezer French...
Our refrigerator lights are all flashing and the
By aklitz on Oct 30, 2009
our refrigerator lights are all flashing and the ice dispenser continuously opens and closes.
Solution #1
posted on Oct 30, 2009
Somewhat Helpful)
johnrray7526
Rank: Guru
Rating: 90%, 405 votes
I have reviewed your problem and have the fallowing for you to aces.
This sounds like to have had a power serge and a possible problem in a power board.
Please try the fallowing.
First, disconnect the unit from its power source.
Next, please check voltage at the power source and verify that it is correct.
Next, please check the ice maker and remove any ice or particles that may be restricting normal operation.
Note... I assume that the unit is cooling and freezing properly, as you have no listed complaints.
Note..... I am asking you to disconnect the unit from its power source and not turn unit off and control panel.
Also, You will want the unit to sit for at least 10 minutes with power disconnected, in order for the unit to reset.
Finally, please re-connect the power source and in available, please push reset on panel.
I the unit work properly afterword's, please have unit serviced asap.
Please let me know if you need anything.
Please rate......
Was this helpful?
Yes
No
Popular Solutions for Maytag MFI2568AES Stainless
Questions and Unsolved Problems for Maytag MFI2568AES Stainless
Do you recommend Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator?
Answer
Answer
The flap in the control panel for the ice maker is uncontrollably flapping and making a rather loud... (More)
Answer
when the ice comes out of the tray it's one pice so it wont bark apart.i need to know if i can set... (More)
Answer
how do you remove freezer door on Maytag MF 12568AEW. I dont have manual and need to move it.
Answer
water just started pouring out of the door ice/water dispenser...ice maker has not been making ice... (More)
Describe your Refrigerators problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerator Experts
Top Refrigerator Repairmen
in Newport, KY
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
