Question about Radio Communications
Tevion car radio 5705
Can I operate this model with 2 speakers rather than 4 as is suggested in the instructions supplied as I don't fancy messing around fitting another 2 speakers
    Novelist:
    Champion:
  • 211 Answers
Yes Phil, The radio will work on 2 speakers except, you should add an 8 - 10 ohm 10 watt resistor to the output wires of any speaker that is not hooked up ( to protect the audio output chip)
Good Luck
Ed]
NC Electronic
Mills, Wyoming
Posted on Jan 07, 2008
I have an 2002 Nissan altima and DA display on the radio is working but no sound
Hi candy Love , I love that name ! What Altima ? S ,SE or SL
AUDIO
Revision: May 2004 2002 Altima
AUDIO PFP:28111
System Description EKS002KQ
BASE AND MIDLINE SYSTEM
Refer to Owner's Manual for audio system operating instructions.
Power is supplied at all times
 through 15A fuse [No. 31, located in the fuse and fusible link box]
 to audio unit terminal 6.
With the ignition switch in the ACC or ON position, power is supplied
 through 10A fuse [No. 6, located in the fuse block (J/B)]
 to audio unit terminal 10.
Ground is supplied through the case of the audio unit.
Audio signals are supplied
 through audio unit terminals 1, 2, 3, 4, 13, 14, 15, and 16
 to terminals + and - of front door speaker LH and RH
 to terminals + and - of rear door speaker LH and RH
 to terminals + and - of tweeter LH and RH.
BOSEĀ® SYSTEM
 to audio unit terminal 6, and
 to Bose speaker amp. terminal 1.
Ground is also supplied
 to speaker amp. terminal 17
 through body ground B117.
 to speaker amp. terminals 23, 24, 25, 26, 27, 28, 29, and 30.
Audio signals are amplified by the speaker amp.
The amplified audio signals are supplied
 through speaker amp. terminals 2, 3, 9, 10, 11, 12, 13, 14, 15, 16, 18, and 19
 to terminals + and - of subwoofer LH and RH.
SPEED DEPENDENT VOLUME CONTROL (MIDLINE SYSTEM AND BOSE SYSTEM)
If activated, the radio output volume will be automatically adjusted to compensate for increased driving noises
at higher driving speeds.
The radio receives a vehicle speed signal from the combination meter, and selects the output volume.
Feb 01, 2015 | 2002 Nissan Altima
Where can i get a connector for my in car cdplayer tevion 5705
1) you two options a) in your supplier dealer
b) or the factory from the radio.
God bless you
Sep 23, 2012 | Televison & Video
Since I purchased my 2009 dodge journey I have had an issue with my radio/cd player ... sporadically the volume goes out, if I turn it off, and on it comes right back on, but will only stay on for 20...
AUDIO Any diagnosis of the Audio system should begin with the use of the scan tool. For information on the use of the scan tool, refer to the appropriate Diagnostic Service information.
For complete circuit diagrams, refer to the appropriate wiring information.
AUDIO SYSTEM DIAGNOSIS
CONDITION
POSSIBLE CAUSES
CORRECTION
NO AUDIO AT ALL SPEAKERS - RADIO DISPLAY AND CONTROLS ARE OPERATIONAL 1. Amplifier fuse faulty, if equipped. 1. Check and replace fuses, if required. 2. Wiring to amplifier faulty, if equipped. 2. Verify radio on/off input to amplifier and verify battery and ground connections. Repair wiring as necessary. 3. Radio faulty. 3. Refer to appropriate Diagnostic Service Manual. 4. Amplifier faulty, if equipped. 4. Replace amplifier. NO AUDIO AT SOME SPEAKERS - RADIO DISPLAY AND CONTROLS ARE OPERATIONAL 1. Wiring faulty between amplifier and speaker. 1. Repair wiring as necessary. 2. Wiring faulty between radio and amplifier. 2. Refer to speaker diagnostics. Repair wiring as necessary. 3. Wiring faulty between radio and speaker. 3. Check wiring for open or short, repair wiring as necessary. 4. Speaker(s) faulty. 4. Refer to speaker diagnostics. 5. Amplifier faulty.
5. Replace amplifier. 6. Radio faulty. 6. Refer to appropriate Diagnostic Service Manual. POOR AUDIO AT ALL SPEAKERS - RADIO DISPLAY AND CONTROLS ARE OPERATIONAL 1. Power/ground wiring to amplifier open or shorted. 1. Repair wiring as necessary. 2. Power/ground wiring open or shorted. 2. Repair wiring as necessary. 3. Amplifier faulty. 3. Replace amplifier. 4. Radio faulty. 4. Refer to appropriate Diagnostic Service Manual. POOR AUDIO AT SOME SPEAKERS - RADIO DISPLAY AND CONTROLS ARE OPERATIONAL 1. Wiring faulty between amplifier and speaker. 1. Repair wiring as necessary. 2. Wiring faulty between radio and amplifier. 2. Refer to speaker diagnostics. Repair wiring as necessary. 3. Wiring faulty between radio and speaker. 3. Check wiring for open or short, repair wiring as necessary. 4. Speakers faulty. 4. Refer to speaker diagnostics. 5. Amplifier faulty. 5. Replace amplifier. 6. Radio faulty. 6. Refer to appropriate Diagnostic Service Manual. SOUND DISTORTION (VIBRATION FROM SPEAKER AREA, BUZZING - HUMMING) 1. Door trim panel loose or missing fasteners. 1. Inspect door trim panel and correct as necessary. Replace any missing fasteners. 2. Water shield loose or misaligned. 2. Inspect water shield and adjust as required. 3. Items placed in door trim panel map pockets vibrating or moving from side to side. 3. Remove items from door trim panel. Ensure that vibration is no longer present. NO RADIO DISPLAY - AUDIO AND CONTROLS ARE OPERATIONAL 1. Radio faulty. 1. Refer to appropriate Diagnostic Service Manual. NO RADIO DISPLAY - AUDIO AND CONTROLS ARE NOT OPERATIONAL 1. Fuse faulty. 1. Check radio fuse and Ignition-Off Draw (IOD) fuse in Junction Block (JB). Replace fuses, if required. 2. Radio connector faulty. 2. Check for loose or corroded radio connector. Repair, if required. POOR RADIO RECEPTION WITH KEY IN ACCESSORY OR IGNITION ON POSITION 1. Antenna faulty. 1. Replace the antenna. 2. Radio ground faulty. 2. Check for continuity between radio chassis and a known good ground. There should be continuity. Repair ground, if required. 3. Radio noise suppression faulty. 3. Repair or replace ground strap as necessary. 4. Radio faulty. 4. Refer to appropriate Diagnostic Service Manual. 5. Faulty rear window defogger. 5. Verify that the rear defogger grid is functioning properly, repair as necessary (Refer to 08 - Electrical/Heated Glass - Diagnosis and Testing). NO COMPACT DISC OR DVD OPERATION 1. Faulty CD/DVD. 1. Insert known good CD/DVD and test operation. 2. Foreign material on CD/DVD. 2. Clean CD/DVD and test operation. 3. Condensation on CD/DVD or optics. 3. Allow temperature of vehicle interior to stabilize and test operation. 4. Faulty CD/DVD player. 4. Refer to appropriate Diagnostic Service Manual.
Nov 01, 2017 | 2009 Dodge Journey
I have a tevion car radio cd player model 2413 but dont have the 16 pin harness plug where can i get one thank you
You could contact Tevion support forum here
or go to ebay and type in 16 pin car audio as your search, you may find what you are looking for there. I haven't seen one, is it a standard iso type?
Surely if it is Tevion specific there should have been one with the radio?
Mar 06, 2011 | Car Audio & Video
Cd player doesnt work and states ''error 06''
If you all ready try cleaning the CD lens now the next step is disconnecting the negative wire from the car battery for about 10 min. but make sure that you have the radio code before disconnect the battery or make sure that your radio does not have a security code, if nothing happen after this try you must send the radio for repair usually they have to replace de CD lens. Good luck
Jan 02, 2010 | Car Audio & Video
Instruction manual for a Tevion clock radio
how to set the alarm on Tevion fm/am digital alarm clock
Oct 23, 2009 | Audio Players & Recorders
Tevion 5705 wiring
just take your deck to your local car audio shop and show em what you need it will cost you about twenty dollars though
Jul 04, 2009 | Kicker TS10L52 Car Subwoofer
The usb connection on my new Tevion 5705 won't read the music from my usb key. the usb key has been re-formatted to a FAT, and then a FAT32, file system and we have then copied the DOS files onto the usb...
Hello I have the same problem but no body do answers . Maby we change radio {panasonic or oder :-). The usb connection on my new Tevion 5705 won't read the music from my usb key. the usb key has been re-formatted to a FAT, and then a FAT32, file system and we have then copied the DOS files onto the usb key along with music files in mp3 & W4ma types though we still can't seem to get the Tevion 5705 car radio to read the music from the usb key when inserted. We keep getting an 'Error 13' message, can someone please help . my email : zadychladislav@hotmail.com Ladi
Aug 13, 2008 | Car Audio & Video
How to wire in
Try this link - it's a PDF of the Owners Manual for a Radio Shack "Noise-Cancelling Dynamic CB Microphone" - Cat. No.: 21-01177
http://www.radioshack.com/graphics/uc/rsk/Support/ProductManuals/2101177_PM_EN.pdf
Page 3 has a chart for wiring/re-wiring the 5-pin DIN connector for other radios - lists wire colors & functions
62248d5.jpgHope that helps,
Rick T.
Dec 26, 2007 | Radio Communications
Radio Communications Logo
430 people viewed this question
Top Radio Communications Experts
Steve
Marvin
Marvin
Are you a Radio Communication Expert? Answer questions, earn points and help others
