you most likely have a light engine problem ocouring causing the pink spots they usualy have to be replaced with a remanufactured light engine you might see if you got a extended warranty on the unit as this can be a tad expensive
I was watching TV and the screen went black. I turned the tv off and on and its still black. I also...
(More)
I was watching TV and the screen went black. I turned the tv off and on and its still black. I also heard a low buzzing sound from the back, has the bulb burned out?
TV turns off after 5-10 min. Replaced the bulb about 2 months ago. Couldnt reset the timer because I...
(More)
TV turns off after 5-10 min. Replaced the bulb about 2 months ago. Couldnt reset the timer because I don't have the original remote. Lamp Light has stayed on and message comes on when turning on TV. Now the tv stays on 5-10 minutes and then powers down like sonmeone shut it off. You can turn it back on again without unplugging but same thing happens. Does this have something to do with not resetting the timer or is the bulb going bad or is it something worse?
TV was working fine this morning. Turned it on this afternoon and no picture. Green power light...
(More)
TV was working fine this morning. Turned it on this afternoon and no picture. Green power light comes on and flashes. TV makes a faint rapid clicking noise that might repeat a few times.
pink dot in the middle of the screen about the size of a softball on shows up with light colors on...
(More)
pink dot in the middle of the screen about the size of a softball on shows up with light colors on the screen
