Question about HP Compaq Business d530 PC Desktop
Red light
The Power light is red (not blinking) and i can't install xp or any windows OS..
  • Anonymous Jan 08, 2008
    I had the exact same problem. I found that the mount for the cpu cooler broke and was no longer touching the cpu. The cpu was overheating and shutting down.
  • 1,601 Answers
System does not power on and the LEDs on the front of the computer are not flashing.
System unable to power on.
Press and hold the power button for less than 4 seconds. If the hard drive LED turns green, then:
1.Check that the voltage selector is set to the appropriate voltage.
2.Remove the expansion cards one at a time until the 3.3 V_aux light on the system board turns on.
3.Replace the system board.
Press and hold the power button for less than 4 seconds. If the hard drive LED does not turn on green then:
1.Check that the unit is plugged into a working AC outlet.
2.Open hood and check that the power button harness is properly connected to the system board.
3.Check that both power supply cables are properly connected to the system board.
4.If the 3.3 V_aux light on the system board is on, then replace the power button harness.
5.If the 3.3 V_aux light on the system board is off, then replace the power supply.
6.Replace the system board.
Posted on Jan 02, 2008
Why is my power light blinking red on my coby tablet?
You won't find a manual. Coby went out of business several months ago. It might be time to replace it. Sorry.
Aug 02, 2014 | Coby MID70244G 7 KyROS TABLET TOUCHSCREEN...
In my laptop windows-XP was installed. then i installed windows-7. then i installed linux Red Hat. die to some problem of internet connectivity, i had to replace redhat by fedora. after successful...
NTLDR means ............New Technology Loader ...........
this is one of the most crucial part of the Windows OS, this specific component looks for the loader of NT(Windows OS) which loads the required OS files of WinXP(earlier it was called WinNT)...the naming legacy is still being followed though the OS has changed from Win95, 98, NT, 2000, XP, Vista, Win7....
The only way u can get back this is by re-formating the drive using the WinXP disk....more info the link
Sep 26, 2010 | Computers & Internet
When i install windows xp harddisk could not found and red light has blinking what can i do
hi ajmalnizar_n,
Try to check if your harddisk is detectable in Bios if so,
The problem is in the installation of windows xp. install a new copy
of Xp. Reformat the disk using ntfs then create your partion if you like.
Hope this helps, Feedbacks appreciated
Sep 03, 2010 | Seagate (ST3160827AS) 160 GB Hard Drive
Red light blinking on my zte relince net connect modem
That's got nothing to do with windows 7. You have a problem with that modem. Oh & if you're trying to use windows 7 on a dial-up connection,it's not going to work well. Microsoft pretty much stopped any support for dial-up on the newer operating systems. So if this is your situation,I'd downgrade to xp, vista won't do well either. Now if the modem you refer to is a dsl or cable modem, try "power cycling" it by unplugging it for 30 seconds & plugging it back in. Do this with the pc off until the lights on the modem are normal again. Then plug the pc back in & see if it's ok. If not,call your ISP & talk to tech support. It'll be on thier end.
May 16, 2010 | Computers & Internet
I have HP laptop with Windows OS.Can I ADD Windows XP OS?
yes you can install winxp if you have winxp bootable disk.
Boot your computer with winxp disk.
For that insert winxp disk into cd or dvd rom then when you power up press F8 or F5 or F12 to get first boot option then set first boot as your cd or dvd rom then you can boot computer with disk.
Jul 29, 2009 | Computers & Internet
Folder with blinking question mark in it after start-up
Folder with a blinking question mark means a missing system folder, in other words there isn't an OS installed. To fix this you need to boot from the OS X installer CD. With the OS X installer CD in the drive, hold down the C key on your keyboard when you start your mac. This tells the mac to boot from the optical drive (i.e. CD drive) and load the OS X installer. From there just follow the onscreen instructions to install OS X.
Also, you should be aware that the ibook is not compatible with Windows XP. Only the newer “intel macs” of the past few years are compatible with XP. Your mac predates Apple's transition to intel processors and Windows XP compatibility on the mac platform by a few years. This is why your Windows XP CD didn't load on it. The ibook is Mac OS X only.
It only runs on Mac OS X however it is compatible with newer versions of the OS. 10.2 jaguar is kind of old and a little buggy. You may want to consider installing 10.4 Tiger for improved stability and performance. Avoid the newest version (10.5 Leopard) as it is geared towards newer and faster machines.
Hope this helps. Enjoy your mac
Feb 03, 2009 | Apple Computers & Internet
My D & E drive is not opening on double click.
parental control pin codes for the box so the new codes can be installed
Dec 28, 2008 | Computers & Internet
Crashing during Windows Setup
Check out any hardware that doesnot supports windows xp. remove that and reload the os. it works. or remove all the additional addon cards like modem, network card, printers etc., (just maintain only hard disk, cd rom and floppy drive)then install the os. once os installs add the components one by one to so that the os will detect one by one cheers!
Sep 17, 2006 | Microsoft Windows XP Professional for PC
HP Compaq Business d530 PC Desktop Logo
354 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
