Question about Microsoft Basic Keyboard 1.0A PS/2 KEMIBA
F Keys Hi, this is a very good keyboard, but from the day i bought it, the F keys don't work.(F!,F2,F3...) why this happens?  and can be fixed?
  • Clanlord Jan 02, 2008
    ι opened the keyboard where there are 3 Transparencies.i pressed all the white dots and all worked except only the F keys.
    Now?
    Sniper:
  • 74 Answers
Yes you can fix it ....it sound to me like a bad assambly case..all you got to do is open by tne back carefully acomodate de parts in good position and that is..be carefull if you put de keyboard in your lap all the keys will coming out with little skill you will do it...good luck and rate me
Posted on Jan 02, 2008
  • take123 Jan 02, 2008
    I am sorry that must be a crack in some conductor foil and as I know it cant be fix just a new one......good luck..
I need a keyboard manual for an Aires K3 seven colour keyboard
Function Keys(for Aires 3 colour keyboard , so i'm guessing will be the same)
Fn + Esc:4 levels backlit brightness adjustable,suitable for use days & nights
High light - Medium light - Respiration light - Extinguish (High brightness by default when starting up).
7 Multimedia Shortcut Keys: Stop, Fast forward, Rewind, Play/Pause, Volume-, Volume+, Mute
3 levels keyboard speed adjustable:
Fn+F1 : 21 byte per sec(80/S)
Fn+F2 : 30 byte per sec(60/S)
Fn+F3 : 63 byte per sec(40/S)
Fn Multimedia Combination Keys:
Fn + F4 Mute
Fn + F11 Lock/Unlock all keys
Fn + F12 Lock/Unlock Windows Key
FN + W : Switch WASD keys and Arrow keys.
Fn + Tab:3 colors adjustable backlit
Jan 28, 2017 | Audio Players & Recorders
Wireless on/off button don't work but did is there a place to enable\disable that buttton
check ur keyboard top keys u would able to see the picture of the tower with rays(check the keys like F1,F2,F3 ) next to it just select that and it could be disabled/enabled
May 25, 2011 | HP Pavilion ze4630us PC Notebook
I need to know what are the function keys on a keyboard
Hello earthaalford:
Your function keys are usually located on the top row and are labeled F1,F2,F3 and so forth. The function of those keys depends on what program you are currently operating in ie: Windows, Office , Word, Excel or any number of other programs.
Hope this helps, if it did just click the thumbs up.
Sincerely, Peter N.
Mar 22, 2011 | Compaq Keyboard
I have compaq 116tu laptop.but dont know how to use keys F2 & F3 for decreasing light intencity of screen.kindly help me which keys were used together.
Hi, you should find a key that has an F or Fn on it and normally has a square around and would be on the left of the space bar... once you find it you can hold it down and click the F2, F3 keys to control the sound... good luck
Jan 26, 2011 | Computers & Internet
My display dimming keys are not working, all other keys are working it is the f2 f3 keys,
try blowing out all of the dust from your keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines.
dust causes static which causes lots of problems with a computer and its parts
or if this does not fix the problem
click start control panel keyboard you can change your settings there
or you might have uninstall the keyboard restart your computer then reinstall it and its drivers
click start control panel keyboard hardware then properties you should see driver details,update driver,roll back driver,uninstall
make sure you have the driver for the keyboard before uninstalling the driver
make sure the lead is good and has a secure connection diconnect the keyboard then reconnect it then reinstall the driver
hope this helps
Jan 21, 2011 | Computers & Internet
MS wireless 1000 keyboard function keys
The "F Lock" is a dual function key,try pressing this key and should fix your problem.
Miklo
Jan 26, 2010 | Microsoft Wireless Optical Desktop 1000...
The keys of my laptop are getting crazy!
Hi there.
There is a possibility that the keyboard is degrading and may need replacing which is not un-common, or the keys maybe sticking due to hair, biscuit crumbs, dust etc which is lodged under the keys.
The best way to check is to turn the laptop off, turn it on its side with the lid open, get a soft, clean paintbrush and clean the keys gently tapping on the keyboard to knock out the foreign objects.
If you still suffer the same symptoms then it will be the keyboard that needs to be replaced.
If you still have warranty, take advantage of that and send it to be repaired for free.
Good luck and thanks for using FixYa!!
May 26, 2009 | Dell Inspiron 1000 Notebook
Keys on my SK9920 stick...how do I clean it?
The same thing happened to me with my gateway keyboard. The f2, f3, and f4 keys were stuck down in the keyboard itself. I just wanted a quick fix, so I soaked a paper towel, rung it out, and cleaned the keys like that, all the keys work wonderfully now
Dec 28, 2008 | Gateway 2520915 Keyboard
F Keys Do Not Work
try useing a usb keyboard this will work
Oct 28, 2008 | AMD Athlon 64 X2 4200+, 2.2 GHz...
Open Questions:
See all Microsoft Basic Keyboard 1.0A PS/2 KEMIBA Questions
Computers & Internet Logo
379 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
