Maytag Neptune MDG5500AW Gas Dryer
Problem for Maytag Neptune MDG5500AW Gas Dryer
Dryer cycles heat once and then does not relight.
By ec188353 on Oct 30, 2009
Dryer cycles heat once and then does not relight. All screens and ducts clean. Replaced flame sensor earlier today. Seemed to work testing but did not when tried to use. Temp sensors bad?
Best Solution
posted on Oct 30, 2009
Very Helpful)
Controlfrk
Rank: Guru  Maytag Expert
Rating: 94%, 90 votes
It's likely one of the coils is opening a break in the coil as the coil heats up. This coil will shrink when cool and be able to run again, generally for only one short cycling of the gas flow. The number for the coil kit, which will replace ALL the coils, for your machine is 12001349.
Disconnect power and turn off gas before working on this dryer. Working on gas dryers is not recommended for people who are not professionals.
Gas components will be on left. Replace All coils with Kit Number listed above. Take care not to touch or hit the ignitor or you will be replacing it also. It is VERY brittle.
Service on gas appliances should be undertaken by professionals only due to the danger of gas leakage which can cause fires or death by asphyxiation.
The link below is a service manual for your machine and covers testing and replacement of the parts above. Good Luck.
http://www.mediafire.com/file/zrlyi1izwly/MDE5500
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Maytag Neptune MDG5500AW Gas
Questions and Unsolved Problems for Maytag Neptune MDG5500AW Gas
Do you recommend Maytag Neptune MDG5500AW Gas Dryer?
Answer
Answer
maytag gas dryer, ignitor comes on, gas valve opens, ignites gas, runs for 30 sec the shuts down.... (More)
Answer
My lint trap on my Neptune Maytag Dryer is not collecting the lint. All the lint is going through... (More)
Answer
A thin carbon film is deposited inside the drum after using 6 or 7 times
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Maytag Neptune MDG5500AW Gas...:
Top Dryer Experts
Rank: Guru Guru
Solutions: 14851
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Dryer Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
