Kicker Solo-Baric L7 S15L72 Car Subwoofer
Problem for Kicker Solo-Baric L7 S15L72 Car Subwoofer
I have 2 1100d's(directed amplifiers). I am
By samson_3000 on Oct 30, 2009
I have 2, 1100d's(directed amplifiers). I am thinking about purchasing 2 Kicker L7 15's. How would I run the amps to the subs? and which ohm load of subs should i purchase(2 or 4 ohm)? Would the 1100d's be enough power to them, and how much power would be going to them?
I am thinking that the amps are 4 ohm stable but not sure. I would appreciate it if you know or could find out. thanks
I also have a 5 farat capacitor. Would this also help?
I will putting the system in a Chevrolet avalanche and because of it being a truck basically instead of an SUV with the enclosure being behind back seat, i thought i would buy the L7's to get more sound since i lose alot going out with JL audio subs i have
Best Solution
posted on Oct 30, 2009
Very Helpful)
mikelpoynter
Rank: Guru
Rating: 93%, 78 votes
From what I have been told these amps are great. You can run anything on these. Now these particular models of the dei amps they make up about 2700 watts. That is true wattage. I would reccomend for you to bridge one sub to each amp. I wouldnt run any lower than a 1/2 ohm. So most likely I would go with the 2ohm speakers. The l7's are a prime choice for anyone. From what it looks like you have a truck? I would recommend to hammer all over the truck and listen to what may rattle. I can gaurantee when you have the subs hooked up you will have windows bowing in and out.
Best of luck to you.
Was this helpful?
Yes
No
2 people thought this was helpful
Asker's Testimonial
" thanks alot.....i appreciate your help " - samson_3000
Solution #2
posted on Nov 01, 2009
Not Rated)
mendozauly
Rank: Master
Rating: 94%, 4 votes
Hey I have the same amp on my Expedition and they go down to a 1 ohm load. They are animals, So get the dual 2ohm Speaker and wire them up to a 1ohm load, to each amp. These amp are class D amp so you cant bridge them they are all connected internally. make sure that cap is as close to the amp as possible. Use 4 ga wire for the power supply. Have a shop or if your good with your hands make a ported box that will let all your neighbors know when your 3 blocks for your house. Have fun.
Was this helpful?
Yes
No
Popular Solutions for Kicker Solo-Baric L7 S15L72
Questions and Unsolved Problems for Kicker Solo-Baric L7 S15L72
Do you recommend Kicker Solo-Baric L7 S15L72 Car Subwoofer?
Answer
Answer
my amp settings was all the way up...and i didnt even realize it... i messed up 2 of my 15s pyle... (More)
Answer
need every thing for a 8" kicker but the magnet and basket
Answer
only one voice coil is working on my L7 10" sub? All connections look good. 2 2ohm subs wired... (More)
Answer
hghjghhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh
Answer
I lost the SLAM or th SPAIR Lockdown Attachment Mechanism (the 4 piece outer mounting ring) for my... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Kicker Solo-Baric L7 S15L72...:
Top Car Speaker and Sub... Experts
Rank: Guru Guru
Solutions: 14851
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Car Speaker and Sub... Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
