Motorola Mobility SLVR L7 Cellular Phone Logo
Posted on Jan 02, 2008
What is my authentication pin??
I`m from Malaysia....
I`m using Maxis operator service(sim card)...
I`ve tried to activate my GPRS....
It needs authentication pin.....
can any of you tell me motorola slvr L7`s authentication pin....
plizz....
reply at....
[email protected]....
thank you...;D
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Jan 10, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
235
Points
Hello samee ur probz is regarding network!!
u need to ask the service provider of corect authentication pin 4 moto L7!u myt type it incorectly or invalid keyword...
4helpful
GPRS SETTINGS FOR LG FATHOM MOBILE
To activate GPRS in your mobile, you need to contact with your service provider. You may need to send some sms as per their rule to activate this service. After activation, generally they will send to the settings as per your handset.
You can only do this: Tap to select the GPRS authentication method. Tap None, PAP Authentication or CHAP Authentication.
Good Luck.
I cant activate my MMS
Title: MMS settings
For Hotlink GPRS Activation
Press *133# to activate your Gprs & MMS
For the setting
1. SMS "GPRS "BRAND" "MODEL" and sent to 22333 example "gprs nokia n70"
2. SMS "MMS "BRAND" "MODEL" and sent to 22333 example "mms nokia n70"
Manual WAP Settings
? On Desk, tab Control Panel -> Internet setup. (or similar)
? Tab New access pt. and tab No, then tab Next and key in the following:
Connection name: Maxis GPRS / Maxis 3G
Data bearer: GPRS
? Tab Next
Network type: IPv4
Auto-retrieve access point: (Unchecked)
Access point: net / unet
? Tab Next and key in the following.
Prompt password at every login: (Unchecked)
Username: maxis
Password: wap
? Tab Next then tab Finish and OK to complete the setup.
? Homepage: http://wap.maxis.com.my/wml/index.wml
? Session Mode: Permanent
? IP adress: 202.075.133.049
? Login Type: Automatic,
? Authentication Type: Normal
MMS Settings
2answers
Get me a new security code of nokia 7210
The PUK code is not related to the handset. It is associated with your SIM card. When you enable the PIN in your SIM card, every time you switch on your phone, you will be asked for your pin. At given number of tries provided by your mobile operator, that you have provided the wrong PIN (usually operators set it at 3 tries), then you came to the stage called PUK-blocked.
To unlock, you would need the PUK code of the SIM card. The PUK code is usually an 8-digit code. This PUK code should have been provided to you when you purchased your SIM card. Some has the PIN-PUK code printed in the card body of the SIM card, while some attach it as a separate print out. Should your operator failed to provide this PIN-PUK code to you, you would have to get it from your operator. Try calling their customer service. Just like the PIN, the operator as well could say how much tries do you have to successfully unblock the PUK of your SIM .
Mar 14, 2011 • Nokia 1100
How to activate the GPRS when i'm using Talk N' Text Sim
GPRS is a service which must be activated through your cellular service provider. GPRS (Data Service) may - or may not - be able to be added to your account. You'll have to contact your cellular provider to determine if you'll need another SIM card if you plan to use Data service.
1helpful
How to open the GPRS of chinaphone
creating data accounts:
Steps:
1. Open Services Menu.
2. Open Data Account.
3. Open GPRS.
4. Create/Edit Data Account and enter the following values:
For Globe MMS Data Account:
Account Name: GlobeMMS
APN: mms.globe.com.ph
User Name: leave it blank
Password: leave it blank
Auth. Type: Normal
For Globe GPRS Data Account:
Account Name: GlobeGPRS
APN: http://www.globe.com.ph
Auth. Type: Normal
For Smart MMS Data Account:
Account Name: SmartMMS
APN: mms
Auth. Type: Normal
For Smart GPRS Data Account:
Account Name: SmartGPRS
APN: smart1
Auth. Type: Normal
5. Save the Data Account.
Configuring WAP/GPRS/Internet Services Using the Data Accounts Created
2. Open WAP.
3. Open Settings.
4. Open Edit Profile.
5. Create/Edit a Profile and enter the following values:
For Globe GPRS Profile:
Rename Profile: myGlobe GPRS
Homepage: http://www.globe.com.ph/globe.asp
Data Account: GlobeGPRS (this data account is the one you have created)
Connection Type: HTTP
Proxy Address: 203.177.042.214
Proxy Port: 8080
Username: leave it blank
For Smart GPRS Profile:
Rename Profile: SmartGPRS
Homepage: http://wap.smart.com.ph
Data Account: SmartGPRS (this data account is the one you have created)
Proxy Address: 010.102.061.046
Proxy Port: 8080
6. Save the Profile.
7. Activate the Profile.
8. WAP/GPRS/Internet services now ready to use. In case you encounter errors, double check the Data Account and Profile created. In some cases you need to restart the phone.
Configuring MMS Using the Data Accounts Created
1. Open Messages.
2. Open MMS.
3. Open Message Settings.
4. Open Server Profile.
For Globe MMS Profile:
Rename Profile: GlobeMMS
Homepage: http://192.40.100.22:10021/mmsc
Data Account: GlobeMMS (this data account is the one you have created)
Proxy Address: 192.040.100.020
Proxy Port: 8080
For Smart MMS Profile:
Rename Profile: SmartMMS
Homepage: http://10.102.61.238:8002
Data Account: SmartMMS (this data account is the one you have created)
Proxy Port: 8080
8. MMS services now ready to use. In case you encounter errors, double check the Data Account and Profile created. In some cases you need to restart the phone.
This configuration is working perfectly using ZT321, Baizhao 8928 and IPhone Clone A380 and probably will work using other China Phones.
If your SIM card is previously activated using other phones specially those phones supported by Globe and Smart, no need to activate your SIM. This is also valid for postpaid users since SIM cards are pre-activated for MMS, GPRS and other services.
But if your SIM is not yet activated or never been used for MMS and GPRS, you need to activate your SIM before you can use MMS and GPRS services.
For Smart SIM, you can use your China Phones to activate MMS and GPRS by simply sending/texting MMS ON / GPRS ON to 333 (I don?t know if this number is still valid). No need to download the configuration for Smart. Just use the configuration I?ve given.
For Globe SIM, this is a little bit harder and need some workaround. I tried to call Globe Customer Service but they cannot activate your SIM manually on their system and the only way to activate it is by downloading the configuration thru text or by asking them to send the configuration. But since China Phones are not yet supported by any Service Provider, what you can do is to active MMS and GPRS using another phone. Monitor until your SIM is activated then transfer your SIM in your China Phone and enjoy surfing and sending MMS.
In another forum, they said you can try using configuration for SE p900. I?ve never tried this but if this really works, well and good for China Phone fanatics.
1helpful
My sim card "No Service" in my iphone
anybody know how to fix lost phone service after jailbreak?
2answers
Unlock Iphone
hi i bought an IPHONE IN UK ( LONDON ) its a latest version 04.02.13_G for V 1.1.2 in that O2 sim is there now am in india i want to use in india how to unlock or any other solution plz hel me out in this its urgent
This is about the authentication??
You can get this from the Support department for you carrier. If it is AT&T, give them a call and they will give you thecode if the service is activated on your account.
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
