Question about Acer Aspire 5500 5570-2609 Laptop
Running Debugger on Safe Mode and Internet Access
I was excited when I got your response however when I was on safe mode, I had two problems. 1. i no longer have internet access even if i logged as the system administrator which means I cannot access the debugger file on the link provided and run it on my laptop. 2. When I downloaded the "debugger" using normal mode and saved it on desktop so I can access it at a later time (on safe mode), I can no longer have it run on my system and it showing that I have restrictions even if i logged as a the administrator. I have no idea what to do next. Once again, please bear with me on this concern. I am just not as literate when it comes to this. But I feel better, knowing something can be done.
    Sergeant:
    Champion:
  • 310 Answers
I would go to my start,run and type in msconfig and click ok and look at your services and start up programs and ether turn off all the things I think could be wrong or just turn all of them off and then close out and reboot. you cant hurt any thing here it is a tech tool. I turn off things one at a time to see if it fixes the problem.
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Posted on Jan 02, 2008
6ya staff
SOURCE:
Reboot acer aspire 4752g laptop to exit safe mode. network diagnostics cannot be run in safe mode
If you download Hirens (Google it) boot disc or USB (150mb file) you will need to USB key installer from the same site and select USB or cd to start first in bios.the boot disc loads a small version of windows Xp on you memory ram.this is as good as safe mode.when the page fully loads you can gain internet access that way .there are hundreds of tools on this programme to fix all kinds of problems and get your laptop up and running.
Dec 10, 2014 | Acer Computers & Internet
My laptop only connects to the internet in safe mode
Boot into safe mode with networking. Download malware-bytes Run a full malware scan, remove any malware and reboot into normal mode. This may have fixed the issue. Failing this download super anti spyware and do the same with that tool. If both these tools come back virus free / do not fix the issue click on start, run. Type 'msconfig' into the box, hit enter. Half the startup items and reboot into normal mode. If you can access the Internet the software causing the problem is in the half of the startup items not running. Keep halving this half until you find the suspect software and remove it. ( no matter how big the number of startup items it will always take the same amount if halfing to narrow it down to one.
Apr 17, 2013 | HP Compaq Presario V2000 Notebook
Cannot get on line in safe mode
safe mode is normally used to troubleshoot problems especially software and drivers. where you use this the computer boots up with minimum software running so you can fix problems. I am sure the modem or network drivers are not loaded and ect.
Jul 12, 2011 | Computers & Internet
Blue screen telling me to contact system administrator technic
Please try hard rebooting the device, this should clear the issue.
If this does not work then try booting Windows into safe mode and restoring the system to a earlyer date.
Good luck.
Mar 02, 2011 | ASUS Eee PC 1005HAB Netbook - Intel Atom...
Have Averatec 3200 series laptop,windows xp.Recently running slow,saying virtual mem too low,so brought to shop to upgread w/1 gb card.Shop installed.Then at home couldnt connect to firefox or internet...
Sounds like Malware/Adware. Try to start in safe mode by pressing F8 at startup. Them start uninstalling unneeded programs. Then install and run cleanup programs. You can use this website as a guide http://csdsolutionsllc.com/cleanup.htm Hope this helps.
Jul 14, 2010 | Averatec 3200 Notebook
Can't access internet wirelessly after 360 install
Try this, start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Feb 15, 2010 | Norton Internet Security 2005...
How do I get into safe mode on HP mini 1000? XP OS
To get into safe mode on any computer running Windows you press F8 before or right after the Windows splash screen comes up. You will have three options for safe mode:
Safe Mode: Only the absolutely necessary drivers load.
Safe Mode with Networking: Same as above plus the ability to use the internet/network access
Safe Mode with Command Prompt: Boots into safe mode with a Command Prompt for command line work.
Hope this helps.
Jesse
Jan 08, 2010 | HP Computers & Internet
The computer will not start at all. It goes into the start up screen. The options to choose from are safe mode start up, etc. It will not go past this. What could possibly be the problem?
Have you actually chosen any of these options? Safe mode is the best-then scan it for viruses. Running in Safe mode you can access internet-it gives you choices. It only runs minimum programs but generally allows you to fix things. Often disabling or removing unecessary programmes from the start menu at this point solves the problem.
Oct 03, 2009 | Dell Inspiron 1525 Notebook
Safe mode
your operating system is corrupted you need to install or repair by running your operating sytem cd
Dec 20, 2007 | Microsoft Windows Vista Ultimate Edition
Acer Aspire 5500 5570-2609 Laptop Logo
63 people viewed this question
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
