FixYa.com
Tags:
Toshiba M665 VCR
Fuses blow afer power surge
posted by BikeBoy on Jan 02, 2008
After a power surge, the VCR blew the 1.6a main fuse. Replacement fuses blow as soon as the VCR is plugged into a power outlet.
I assume a diode and/or cap in the power supply has shorted. I have no schematic and am unable to troubleshoot the power supply or determine the value of some components. Any suggestions?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jan 02, 2008
Thanks for Trying (70)
sedonix
Rank:Guru Guru
Rating: 86%, 437 votes
These are switch mode power supplies and very difficult to repair. If you don't find all the blown components, they just blow up again when you try it. If that model has a separate module for the supply, you can try and order a replacement, but they usually are too expensive.
What model is it? Maybe I have a junker I can take the supply from for you?
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these VCRs problems?
VCRs
Magnavox VHS HQ Model...
The power light does not come... Answer This...
VCRs
tape stuck in vcr
I cannot get my vcr to eject... Answer This...
VCRs
vcr
I got a stuck tape out of my... Answer This...
VCRs
toshiba urc 4220 code
hi,, I have a toshiba tv with... Answer This...
VCRs
Record from Panasonic...
First VCRs are hard to come by... Answer This...
Repair Service
Find VCR Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
