L7680 printer was working fine. It stopped printing black but will print all other colors. I just replaced the black ink cartridge and it still won't print black. Do you know the fix for this?
If you print primarily black, your black/yellow printhead may have worn out and needs to be replaced. Go to start, printers and faxes, select the L7680 and then select properties. Print a test page and run the troubleshooter to clean the nozzles and lines. If it's not the nozzles or lines, search for C9381A on google and purchase a new printhead it should be about $70.
Printer is not printing clear, it comes out likeI am low on ink but I put in new ink cartridges. A...
(More)
Printer is not printing clear, it comes out likeI am low on ink but I put in new ink cartridges. A white line goes through the print
Hi, I own a hp officejet pro l7680 all-in-one printer and i am having problems with it. When I print...
(More)
Hi, I own a hp officejet pro l7680 all-in-one printer and i am having problems with it. When I print something it has a yellow streak on the side of the paper and on the other side of the paper a smudge black streak. Which is making my letters very messy. Do you have a solution to this?
