Magic codes don't work. The best thing you can do is to go down to a cell repair shop. They will most likely have a special cable that will connect your phone to a computer (PC), allowing all the contents of the phone to be seen. The security code is then easily seen on the PC.
It does not cost a lot to do (here it is done at an equivalent of about USD$10 on a bad day). Some people even build or buy their own cables. There are many schematics on the net. Good luck.
Usually the default security code is the last 4 digits of your phone number. But in the case that you changed it and forgot it you can take it back to the retailer and they should be able to flash it back to the default settings. Just keep in mind that it will erase all information you have on it. I.E. Phone books, Pictures, Videos, Games..etc.
I found the solution, all you do is get the master code from security master code generator. Just google that. Type it in and it will probably say incorrect code switch off your phone take out the battery for ten seconds and put back in then don't type master code just type 12345 and it goes through.This is exactly what I did and it worked, if it does not work for you then the only other way is to go to cell phone repair shop and let them plug their cable in and check for you.
Which is the best Cell Phone having the feature of 3G in brand Nokia within price brand of...
(More)
Which is the best Cell Phone having the feature of 3G in brand Nokia within price brand of Rs.10,000. Thanks in advance, jaypoo
I locked myself out once because I needed a PUK code for the Samsung Impression, I called customer...
(More)
I locked myself out once because I needed a PUK code for the Samsung Impression, I called customer care service and then they gave it to me, when I put it in it said I had to change my Pin code, so I changed it and now I forgot it.
How do I change it again ?
hi, my samsung soul is losing the screen, i have to turn it on and off cos the screen goes blank...
(More)
hi, my samsung soul is losing the screen, i have to turn it on and off cos the screen goes blank when i get a text or call. also the screen scrambles. if i keep the top part up it doesnt happen and i think its the slide action not working properly, it is only 12 months old. i dropped it in water about a month ago for a few seconds but it did work properly afterwards.
Sanyo 8100. Lately, I receive a notification of a new text but when I click on the link, there is...
(More)
Sanyo 8100. Lately, I receive a notification of a new text but when I click on the link, there is nothing there. My daughter tried to send me a text while sitting with me on the couch! I keep getting a round about that sends me to the main menu even if I click on my inbox. I can't find any messages now just the notifications. :(
I cant open my securety code. it still should be 12345 since i never changed the code and the phone i got new. what software can i use to check for the code via pc/usb connection.
i can use my phone but need to install the code. tnx
Comment by Guest, posted on May 28, 2008
i put a security code on my phone nokia 6085. when i hurryly run in the step, my phone accidentally felt off from my pocket and it got switch off by itself, when i switch it on and enter the security code which i set some month ago, it says code error. i try again and again but its totally helpless. so, if there is any method/way to unlock it differently, plz remind me.
Comment by Guest, posted on Mar 11, 2008
My security code is not functionning
Comment by Guest, posted on Mar 03, 2008
need security code for my nokia 6085 imei no 354845013655972
Comment by Guest, posted on Feb 29, 2008
imei 353228017395609
i want the secury code please help
e-mail-sahniutsav_ksp@yahoo.com
