Hi if you "google" krups spare parts or krups espresso jugs you will get a few companies who sell spares. Also if you go to krups.com they will list their dealers for spares and accessories.
See page 8
8
8
FIRST USE
Rinse water tank before first use.
Fill water tank with fresh, drinking water. insert
water tank to machine.
Switch machine on. Power button starts
blinking red while machine is heating up for
approx. 40 seconds. Afterwards power button
lights steady green and machine is ready.
40 sec
ON
Push selection lever to the "HOT" position.
Machine starts rinsing.
Open locking handle and insert empty capsule
holder. Close locking handle.
Place jug under outlet.
Push selection lever to the "COLD" position.
After approx. 60 seconds push selection lever
to the "STOP" position. Empty jug and refill
Make sure that the selection lever is in "STOP"
position. Then plug the power plug into a
mains power socket.
to the "STOP" position. Machine stops rinsing
and power button blinks red for about 5
seconds.
8
Place drip grid on drip tray. Then insert drip
tray at desired position of drip tray.
Then insert drip tray at desired position of machine.
Why don't you try "Krups" ? I would think this would be the best place to start. Ask them if they stock the spares and if not where they are available.
Hi there, you could try getting your replacement here
http://www.morphyrichards.co.uk/
they have a wide range of parts and your model is listed, they also have a customer care line and you can buy spare parts online
Hope that helps
Best Wishes
Hi, I have a #872 model. It is very similar to the #871. Where the gasket is there is a small metal filter too, attached by a screw. UNPLUG your coffemaker!!! If you unscrew the filter and remove it with the gasket most likely you are going to find the other side of it clogged by coffee. Wash it off and wash the gasket well too with dishwashing soap. Rinse them off well. You should try to clean off the coffemaker part to where the gasket lays. Usually it is full of burnt of coffee. If there is no other problem with your coffemaker this should solve your problem.
