Question about Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator
Water leaking from bottom of fridge
For the past month we have experienced water leaking from fridge now the temp sensors keeps flashing from green to red why?
  • cc2212 Mar 20, 2008
    Water dispenser dripping after use
    Problem Solver:
  • 8 Answers
Doors might not be sealing? Is it coming from the fridge or freezer? Try turning off for 30 seconds than back on again and try settting the themostat in the fridge at a different temperature - Up or\then down to see if that does anything if you can change it
Posted on Jan 28, 2008
I have an amana bottom freezer fridge. 3 years ago ,y freezer was frosting inside and the fridge temp was not getting cold enought. a repaiman replaced the thermostat. now the freezer is beginning to...
To fix up a frosted up vents, I had a control board replaced for $180. Then 6 months later, the bottom freezer frost up AGAIN. rather than dumping more money to fix it, I was about to buy a new fridge, but had a crazy idea: I disconnected the water to the freezer, bought plastic trays for ice cubes for $3 at walmart. Fridge has worked like a charm for 6 months. no signs of frost. Saved $1000's.
Dec 12, 2011 | Amana ABB1927DE Bottom Freezer...
My GE Profile side by side fridge freeze the food in the bottom draw. I have set the temp to 43F but keep the fridge at 34 or colder. It frooze the water lines and tank in the fridge several times. What am...
You probably have a sensor issues there are two one for the freezer one for the frig. Check your freezer temp it should be at 0 degress at manufactor setting. If the temp is below -10 you freezer sensor is bad. Otherwise your frig sensor is bad. CHECK FREEZER FIRST!!!
May 27, 2011 | GE Profile 25.5 Cu. Ft. Side-by-Side...
I have a national NR-302TE-X fridge for the past 4 months the fan in the freezer gets frozen and stops due to this the fridge does not cool and a lot of water is defrosed and there is water inside the...
dear
there is a temp, sensor in side the fridge that turn on a heater rod and stops compressor that melts the ice at back of freezer and fan.
or toy can open rear panel in side freezer and pure hot water (not boiling ) on frozen ice on condenser coils, this will help you for on week and then you have to repeat it again
you need a good tech person to solve that problem
hope toy under stand
?Adnan : eng-adnanpaul@hotmail.com
Nov 13, 2010 | Refrigerators
Ice forming in the bottom of the freezer
Unclogh the drain hole inside the freezer in the bottom of the bakc wall pouring hot water until the ice melted and keep pouring until goes through.Repet this every 3 or 4 months to keep it clear.
Jul 22, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Bottom freezer temperature rises as high as 35 degrees and drops only to a low of 15 degrees continually. ongoing for a month now. french doors fridge now has temp. fluxes within this past week. temp. goes...
check the defrost thermostat , and any temp sensor that can determine the freezer temperature.
If this fridge temperature is electronically controlled, the freezer control board must also be tested.
Click here to get all parts and diagrams for this fridge.
Regards.
Jul 09, 2009 | GE Profile PFS22MBW French Door...
Frigidiare PLHS39EESS9 Ice build up in bottom of Freezer
I had the same problem with my Jenn-air side-by-side
Your freezer has a defrost cycle and when the freezer temp is set too cold, your drainage pan and tube freezes up (behind the back panels in the freezer) and when that gets full it spills over too the bottom of the fridge and keeps building up until you notice.
  • Un-plug fridge and put your food in coolers or another fridge.
  • Defrost the freezer, remove the ice from the bottom.
  • Remove the back panel/s (in the freezer).
  • Check the drainage pan. If it is iced up, you'll have to carefully remove the ice and check the drainage hole.
  • If the hole is iced up, so is the first 1-2 inches of the plastic tube leading to the main drainage pan behind and under the fridge.
  • You can use a hair drier to speed up defrost.
  • To defrost the hole and tube I used round ended metal (nut pics or beater attachment ends- avoid sharp objects) heated up in boiling water and gently forced down into the hole and tube until defrosted.
  • Check flow(by pouring warm water) down and looking behind and under fridge(with flashlight) to see if flowing into main drainage pan.
  • Turn up your freezer temp and check with a thermometer. Your freezer temp was probably set too cold
Mine is going on 5 months with no problem. If this continues, it might be the defroster.
Good Luck!
Mar 22, 2009 | Frigidaire PLHS39EESS Stainless Steel
SubZero 650 - fridge 36 to 50 deg, vac condensor light flashing
Hi!! you have a seal system problem.A leak in the evaporator..
Dec 26, 2008 | Sub-Zero 650 / O Bottom Freezer...
I have a Hotpoint hss25gfpe ww fridge with ice and water in the door. The ice works, but I am unable to get water. Why can I not get any water? The serial # is tf261776 if this is needed.
Most water dispensing fridges have a tank in the fridge to keep the water cold. If the fridge temp is too low it might freeze the tank and stop the water from dispensing. Also check the water filter to make sure it is not frozen. Water filters should be replaced every 6-12 months, if it's been longer than that it might be too full of dirt to allow water past. It also might be the water inlet valve is not opening.
Jul 20, 2008 | Hotpoint Refrigerators
Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator Logo
533 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
