FixYa.com
Tags:
Hotpoint BWM12 Front Load Washer
Hotpoint BWM - very noisy but not walking accross...
posted by URZS on Jan 02, 2008
Normally this macine operates ultra quietly however recently it has got more and more noisy. I have removed the access panels and although there is some movement, the outer casing is stable. When I lift the internal drum there is some movement so i suspect that the bearings may have gone. If so, do i have to replace both front and back bearings? If so is the thread holding the drum on a right-hand thread? I do have some experience in washing machine repairs but i would welcome any advice.
Comment by URZS, posted on Jan 02, 2008
There is a little play from side to side but not as much as top to bottom. The drum moves freely. The macine is less than 2 years old. How do i remove the rear fly wheel? I can see the bearing and it does seem strange that hotpoint does supply a front and rear bearing kit for this machine so maybe its a model that can replace the bearings. BWM 129
I am really sruggling to get the bolt off that holds the pulley - any tips?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Helpful (85)
vest6
Rank:Guru Guru
Rating: 88%, 131 votes
Remove the back of the machine to expose the inner drum pulley. Need to know if this pulley is rotating and if there is any side to side play.
The noise you are discribing does sound like a rear bearing that is mounted in the external tub housing. Depending on the age of the machine, this bearing is NOT replacable. The outer tub must be replaced because the bearing is molded into the drum.
Comment by vest6, posted on Jan 02, 2008
On most of the front loaders the pulley is held in place by one retaining bolt in the center of the pulley. Remove this bolt and gently pry/wiggle the pulley off the spin shaft. This will allow the inner tub to be push through the machine. Some dissasembly at the front is needed to allow the inner tub to com out.
Comment by vest6, posted on Jan 08, 2008
Sorry so long to get back to you.
This might sound silly. Try turning the bolt in the opposite direction. Might be reverse thread. Also, spraying a little dw-40 or other penetrating oil might loosen it up.
Rating Locked! (?) URZS has rated this solution as Helpful
Can you Help with these Washing Machines problems?
Broken Door Catch on Hotpoint...
Hi, the door handle/catch has... Answer This...
hotpoint BWM 129 washer
Hi Can you help my machine is... Answer This...
hotpoint bwm12 intergrated...
the door wont open and my... Answer This...
How to get access to door...
Hi, When I closed the door to... Answer This...
BMW 129 fault lights
second and fourh are flashing... Answer This...
Repair Service
Find Washing Machine Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
