Question about Cyberhome CH-LDV 700B Portable DVD Player
DVD works but the screen is black and white
I have received the above dvd player as a christmas present the dvd player works but I can't change it from the picture being black and white to colour, can you offer any advice?
  • 979 Answers
Precorded discs, or copies made on a computer? Other than that, getting service will take a miracle, as the company is out of business...accordianman
Posted on Jan 25, 2008
6ya staff
SOURCE:
Will only play DVDs in Black and White
Onkyo DV-CP706B 6-Disc DVD Player (Black) - Amazon.com
www.amazon.com/Onkyo...Player-Black/.../B001AMS...
Amazon.com, Inc.Color: BlackChange .... It's quieter than it was before, and it plays ALL DVDs, even if you can see some visible damage ..... THere was no color-just black & white.
Onkyo dvd player no color only black white Questions ...
www.fixya.com > Forum > Tags > dvd player no color only black white
Onkyo dvd player no color only black white related problems. Ask your Onkyo dvd player no color only black white questions. Get free help, advice & support ...
Onkyo dvd player plays black white Questions & Answer
Dec 29, 2015 | Onkyo Dr-s2.2 5.1 Dvd Home Theater...
DVD player is black and white and screen is split
Make sure the player is compatible with your TV broadcast standards. A Pal player will show b&w pictures when connected to a NTSC tv and vice versa
Feb 26, 2015 | Samsung DVD-V3500 DVD Player/VCR
Tv screen turns black and red when playing through pioneer receiver
Usually when I hear of solid colors that display on a TV, my first solution would be to change the cable. We know your DVD player is working as you connected it straight to your TV and you report no problems. I assume you are using a composite cable (red, white, and yellow) Red and White being the Audio and Yellow your video.
But since your player works...and your tv works under the same input, then the only other issue would be the output cable from the receiver or the actual composite input or output connector is faulty.
try a video game system in place of the dvd player through your receiver..if it happens again, then change the receiver's output cable...if it still persists then your reciever's output connector is faulty.
I hope this helps.
I’m happy to help further over the phone at https://www.6ya.com/expert/anthony_db0df2be5e6f8c0c
Aug 09, 2012 | Audio Players & Recorders
Alba 16inch tv and dvd combi has turned black and white how can i change it back to coulor
Make sure the source is on TV
Press "menu"
quickly type "4725"
select "diagnostic"
choose "factory reset"
If this doesnt get colour back then its broken
Jan 07, 2012 | Alba Televison & Video
Screen is Perfect just Black and White only...No Color
well a dvd player is only going to playback the media it is reading. So if the dvd is a reproduction of a b/w western then b/w is correct but if you play a dvd from the present then it should be in color unless the tv it is connected to is faulty. Try connecting to another tv to see if problem repeats on another tv
Aug 15, 2009 | Protron PD-800 DVD Player
Black and White Image
Yes there is video format for our TV and dvd players. NTSC & PAL...
NTSC SYSTEM SELECTED IN TV & DVD PLAYER PLAY PERFECT NTSC CDS & DVDS, BUT IF PAL CD OR DVD IS INSERTED SUCH PROBLEM COMES.
EVEN IF, THE DVD PLAYER SETTING IS KEPT AS PAL, AND WE INSERTING THE CORRECT CD OR DVD AND ALSO IT SHOW BLACK & WHITE PICTURE, ETC.... so please check your video system in TV, DVD PLAYER and check the CD or DVD you are inserting is of same video format you have set in DVD player.
Apr 23, 2009 | Cyberhome CH-DVD 300 DVD Player
Trying to connect sony dvd player to hdtv
You will need some cables first. It's really not that difficult once you know what each cable does.
Since you're only connecting from the DVD player to a receiver, this should be simple.
There are 4 solutions depending on what cables you have.
Composite - Yellow, Red, and White ended connectors.
S-Video - Black 4-pin connectors.
Component - Green, Blue, Red and sometimes extra Red, White for audio.
HDMI - heavy cable with a wide/flat connector.
Composite connection - Connect the yellow end to the yellow Video Out of the DVD player and to the DVD Video In on the receiver. Connect the Red audio connector to the Red Audio out of the DVD player, the White connector to the White Audio out of the DVD player, and then connect those to the Red and White Ins for DVD Audio on the Receiver.
S-Video Connection - This is the same as the Composite video connection, but connect the black 4-pin cable into the S-Video out of the DVD player and into the In for DVD on the back of the receiver instead of using the yellow video cable. The S-Video cable is a video only cable and uses the same audio cables (the red and white ended cables) for audio.
Component Connection - On the back of the DVD player, connect the 3 video cables that are Red to Red, Blue to Blue, and Green to Green. These will be labeled Y for Green, Cb/Pb for Blue, and Cr/Pr for Red. Connect these video cables to the inputs of the receiver the same way Y for Green, Cb/Pb for Blue, and Cr/Pr for Red. The audio connection is the same as composite and there should be a place on the DVD player that will tell you what audio is for Component. This is also the same on the back of the receiver.
HDMI Connection - This one is the easiest to connect as your audio and video are in the same cable. Plug in your HDMI cable in the back of the DVD player (there should only be one) and then to the HDMI connection for DVD on the back of the receiver.
Now...once you have your connections made, turn on your DVD player, set your receiver to DVD, and enjoy.
If your receiver does not have video inputs, you will need to run the video lines directly to your TV while the audio lines go to your receiver. This will mean you will need to set the receiver to DVD as well as change the channel of the TV to the input you have the DVD player plugged into.
I hope this helps.
May 12, 2008 | Sony DVP-NS725P DVD Player
Curtis progressive scan DVD player 1071
your not using progresive scan out are u change that back to regual
Feb 06, 2008 | Curtis Progressive Scan DVD Player 1056
DVD player - Picture goes from color to black and white
your problemens is in decodor of your tv its a proablem of service
May 06, 2007 | Toshiba MW24F51 24 in. TV/VCR/DVD Combo
Cyberhome CH-LDV 700B Portable DVD Player Logo
136 people viewed this question
Top Cyberhome Televison & Video Experts
Demonic-2011
Demonic-2011
Kahn Chaddock
Level 1 Expert
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
