A wash stopped mid cycle and now whenever I try to start a
new wash the start/pause button is permanently flashing and
nothing I do will make the machine work!
Any help with this matter will be gratefully appreciated.
E20 shows on display checked pump and pipes all clear any sugg
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Press "end of cycle" to finish the mid stoppage..
Rate me pl.....if helped.
Mid way through cycle wash enhance button flashing washing soaking
the buttons on the front panel keep sticking and can't start wash cycle. Keep unplugging and loosening with a knife and spraying WD40. Then will work for a while then start button stops woeking again as if pressing on nothing
