Cars & Trucks Logo
Posted on Oct 29, 2009
What is the transmision fluid capacity for 2005 tayota tacoma truck 2 wheel drive 4 cylinder?
Anonymous
Level 1:
Problem Solver:
  • Contributor 12 Answers
  • Posted on Oct 30, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
12
Questions
Helped
4700
Points
21
Engine type 2RZ-FE manual trans. API GL-5/75w-90/2.7 qts.
Engine type 2RZ-FE Auto. trans. Dexron III/2.5 qts.
Engine type 3RZ-FE manual trans. API GL-5/75w-90/2.6 qts
Engine type 3RZ-FE Auto. trans. T-IV/2.6 qts
Engine type 5RZ-FE manual trans. Hypoid API GL-5/75w-90/2.7 qts
Engine type 5RZ-FE Auto. Trans. T-IV/1.7 qts
1997 toyota tacoma will not go into 4 wheel drive
Has the transfer case ever been serviced? The fluid should be changed every 30,000 miles, if not the works can stick and cause engagement problems. Make sure the vacuum to the front hubs is available, if the front hubs are not locking the front drive shaft will turn but no Front wheel lock up and no 4 wheel drive is available.
I have a 1997 4-wheel drive toyota tacoma. It has a 2.7 ltr. 4 cylinder A34OF auto transmission. I had the transmission fluid changed and we are unsure as to the correct amount to put back. The...
you put ion the amount to bring back to the correct level on the dip stick
unless you have completely drained the transmission AND the torque converter then the amount required is around 1/2 the capacity stated in the book
so start with the 2.1 quarts monitoring the dip stick until you get it on the mark then follow the instructions in the user manual as to starting /running in gear at idle and topping it off as required
Mercedes clk 320 sport transmision type and capacity
Use the new DEXTRON VI ATF, capacity is 4 quarts. (filter and pan drained out)
2005 toyato tocoma stuck in 4 wheel drive
my 2001 tacoma has push buttton 4 wheel drive. It wont go into 2 wheel drive. The fuse in the cab is good. I cant find any other fuses for 4 wheel drive. There is no juice to the switch on the shifter. There is no juice to the plug on the differential or the one on the transfer case. I have checked any grounds I can find and every thing is in good shape. Any Ideas?
7helpful
2answers
Fluid capacities and fluid specs
2000 TOYOTA TACOMA 2.7L 4-cyl Engine Code 3RZ-FE
Engine Oil Grade 1......API* All TEMPS......5W-30 Optional ..10W-30
Engine, 2WD, with filter..........5.5 liters
Engine, 4WD, with filter..........5.4 liters
Manual Transmission,......GL-5/ GL-4 All TEMPS......75W-90
Automatic Transmission,A340E......AF3 / A43D......AF3
Differential, Front/ Rear W/ ADRD......GL-5 ALL TEMPS......75W-90
Differential, Front Less ADRD......GL-5 ALL TEMPS......80W-90
Transfer Case,......GL-4/GL-5 ALL TEMPS......75W-90 Gear oil.
Capacity:
Cooling System, Initial Fill..........8.5 liters
Automatic Transmission, A340E Initial Fill..........1.6 liters
Automatic Transmission, A340F Initial Fill..........2 liters
Automatic Transmission, A43D Initial Fill..........2.4 liters
Automatic Transmission, Total Fill
4 speed A340E..........7.2 liters
4 speed A340F..........10.1 liters
4 speed A43D..........6.5 liters
Manual Transmission, ..........2.5 liters
Differential, With ADRD Front..........1.2 liters
Differential, Without ADRD Front..........1.1 liters
Differential, 2WD V6 Rear..........2.6 liters
Differential, 4WD Extra Long Rear..........2.5 liters
Differential, Short WB With LSD Rear..........2.7 liters
Differential, Short WB Without LS Rear..........2.6 liters
Transfer Case, Electronic..........1.2 liters
Transfer Case, STD..........1 liters
1helpful
1995 Toyota Toyota Tacoma 4WD 6 cylinder 3.4
no, you will tear up the differential.
1helpful
96 tayota tacoma, 2.7 4 wd, the engine is hard to start when the engine is hot. When cold the engine starts fine.
1. air filter dirty. 2. bad engine ground. 3. fuel filter 4. loose connection in ignition system. 5.faulty idle control system.
6helpful
Tranny fluid capacity 95 F150 5.0
Automatic trans??? 2 or 4 wheel drive??
AOD 2 wd- 12.3 qts
AOD 4 wd - 12.3 qts
C-6 2 wd - 12.0 qts
C-6 4 wd- 13.5 qts
E40D 2 wd 15.7 qts
E40D 4wd 16.2 qts
4R7OW - 14 qts
1helpful
3answers
What is the toying capacity for a 2005 toyota tacoma 4 cylinder.
http://www.toyotaoffroad.com/articles/Toyota/2005_Tacoma/2005_Tacoma.htm
1helpful
2003 toyota tacoma
0 deg 09' +/- 12' (0.15 +/- 0.2 deg, 1.6 +/- 2 mm, 0.06 +/- 0.08 in.)
Top Toyota Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Toyota Expert? Answer questions, earn points and help others
