Your Panasonic camera has a USB port on it as associated by the accompanying cable that plugs into it and has a USB end on the other cable. Note that if your videos are on the SD card, you can take it out and put in your computer via a SD adaptor to USB. The hard drive files though are a little more tricky... you have to have the camera being fed by the AC adaptor instead of the battery.. (it looks like the battery and plugs into its hole on the bottom with a cable hangiong out that plugs into the battery charger.. You will not be able to transfer the files unless you have this power configuration.. this is to keep the transfer from being disrupted by running out of battery power. The files are MOD files which are MPEG2 files just renemed. You can rename them to MPG instead of MOD once you copy to the computer. The USB connection forces the PC to make a drive letter for the hard drive in the camera. I hope that helps out
you need a 1394 firewire pci card installing in your pc before you can transfer DV footage over, or you can copy the footage to a DVD recorder via lead, then put the disc in your dvd rom drive and copy it to your pc.
i have this camara panasonic handycam.zoom in- zoom out options not worked. LCD monitor is fogged....
(More)
i have this camara panasonic handycam.zoom in- zoom out options not worked. LCD monitor is fogged. 'push the reset button' is again and again blinked. but playback mode is working freqvently. please solve my problem
Can i transfer the video recored on the HDD of mt Panasonic sdr-h40 to the SD card? i want to put...
(More)
Can i transfer the video recored on the HDD of mt Panasonic sdr-h40 to the SD card? i want to put the card straight in my laptop reader.
When I start load of video cam suite 1.0 it says not compatible with my service pack. I have Windows...
(More)
When I start load of video cam suite 1.0 it says not compatible with my service pack. I have Windows XP version 2002 service pack 3. If I go ahead and load when I start up it gets error and shuts down.
