Check for bad solder connections on the convergence board. convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks! See link for more detail http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
When I play a dvd it does not hold a solid picture. I have changed dvdv player and cables to no...
(More)
When I play a dvd it does not hold a solid picture. I have changed dvdv player and cables to no avail.
I'm having the same issue with my Toshiba 50H72, constantly flickering, like a power problem,...
(More)
I'm having the same issue with my Toshiba 50H72, constantly flickering, like a power problem, however, it almost completely clears up when I switch the input to a HD input. Any idea what I can do to fix it? Is there some part that I could replace to fix this? I don't want to buy a new set yet, if it's a minor repair. Thanks, Larry
