hello sir, loss of power or transmission will not operate in either direction.a, broken or slopping drive belt.b. broken speed control linkage.c, low transmission oil level.d, wrong transmission oil or contaminated oil. e, transmission oil too hot. f, transmission roll release valve in wrong position.g, plugged oil filter.h, faulty charge pump or charge pressure relief valve. i, worn or damaged transmission pump and/or motor. j, drive pulley slipping on the transmission input shsft. k, internal damage to the reduction gear assembly. this is for a hydrostatic transaxle transmission, though i would give you something to do and check,hope this helps,MrFixIt,oh could you please rate this solution,thank you.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Craftsman 42 in. Deck 19.5hp
need JD 108 schematic I get a intermittent spark. I have replaced the magnito and spark plug. I am...
(More)
need JD 108 schematic I get a intermittent spark. I have replaced the magnito and spark plug. I am getting fuel and it turns over like crazy.
Ihave a simalar problem with a42 inch crafstman lawnntractor when i deprees the clutch will not go...
(More)
Ihave a simalar problem with a42 inch crafstman lawnntractor when i deprees the clutch will not go into gear.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
