Automatic shutoff red ball in recovery tank rises to top when recovery tank is about 20% full.Thus we are only able to use the steam cleaner for about 2 minutes before having to empty the recovery tank. Ideas to resolve ?
Your cleaner should have a foam sock around the float cage in the recovery tank. Remove the foam sock and rinse it out with clean water. If these are very dirty, they may cause the airflow to be disrupted, causing the float to raise prematurely.
Brushes on Hoover Steam Vac F7441-980 do not turn.Brush control on;drive pin present;filter intake...
(More)
Brushes on Hoover Steam Vac F7441-980 do not turn.Brush control on;drive pin present;filter intake clean; Drive mechanism doesn't appear to be turning. Also when spraying on cleaning solution, spray comes out in streeks rather than the width of nozzle. JBB
the upholstery attachment won't slide down to meet the opening for suction. Don't know how to attach...
(More)
the upholstery attachment won't slide down to meet the opening for suction. Don't know how to attach it.
