This should help, this is the pdf manual on netgear wireless routers with all detailed information on how to do everything with the router. http://kbserver.netgear.com/pdf/wireless_router_setupmanual.pdf
If the NetGear has a Security Key (password) , only you or the person that set it up will have the password. Has it been secured? Here is a user manual: http://www.lmi.net/wp-content/uploads/WNR2000.pdf
To RESET the Netgear, power up the Netgear then press andhold the RESET button at the back of the router until all the LEDs flash.Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL - http://192.168.0.1 The default login = admin The default PW = passwordYou can now change the default admin password and configurethe wireless settings. Go to the wireless configuration and set up the SSID and WPA or WPA2encryption. Apply these settings to the wireless card in your laptop/computer. To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
to configure the netgear router and to secure its network. . . .1, first make sure that your laptop is connected directly to the netgear router via ethernet cable.2. after securing step 1, on your computer, open browser, ( internet explorer or firefox )3. go to the address bar, the one with the http:\\ and erase everything inside it.4. type in there, 192.168.1.1 or www.routerlogin.net.5. username is " admin "password is " password "6. you would see netgear set up wizard. 7. for wireless configuration, click wireless settings on the left side of the set up wizard.8. you can edit network name, and get your network security key under security options. make sure to choose WPA PSK TKIP. so that you can have a personalize network key9. the network security key is the " passphrase "then click apply.then your all set for wireless connectivity.
to configure the netgear router. . . .1, first make sure that your laptop is connected directly to the netgear router via ethernet cable.2. after securing step 1, on your computer, open browser, ( internet explorer or firefox )3. go to the address bar, the one with the http:\\ and erase everything inside it.4. type in there, 192.168.1.1 or www.routerlogin.net.5. username is " admin "password is " password "6. you would see netgear set up wizard. 7. for wireless configuration, click wireless settings on the left side of the set up wizard.8. you can edit network name, and get your network security key under security options. make sure to choose WPA PSK TKIP. so that you can have a personalize network key9. the network security key is the " passphrase "then click apply.
The default password for the router's Web Configuration Manager is password. NETGEAR
recommends that you change this password to a more secure password.
To change the administrator password:
1. On the main menu, under Maintenance, select Set Password to display the Set Password
screen.
2. To change the password, first enter the old password, then enter the new password twice.
3. Click Apply.
Best of luck!
Use an Ethernet cable to connect a computer to any one of the four LAN ports of the NETGEAR router.
In a web browser, enter the router's IP address - either http://192.168.0.1 or http://192.168.1.1 by default.
When prompted for a Username and Password, enter the default username and password (admin; password) unless you have already changed it. NETGEAR recommends changing the default password to increase the security of your network.
Select Wireless Settings from the Setup menu in the left-hand navigation bar.
Under Wireless Network, enter your desired network name in the Name (SSID) box.
Under Security Options, select WPA-PSK [TKIP] + WPA2-PSK [AES].
Under Security Options (WPA-PSK + WPA2-PSK), enter your desired network password into the Passphrase box.
WRITE DOWN or KEEP NOTE of your network name, security option and passphrase - you will require them to connect wireless computers and devices to your network.
Are you referring to the password required to connect to your wireless network called "Netgear"? I assume you're being asked for a password on the 2nd computer when trying to connect to the wireless network called "Netgear".
Under Wireless Network, enter your desired network name in the Name (SSID) box. This is currently set to "Netgear" most likely.
Click Apply to save the settings.
Once you've set this password, you can use it to connect to "Netgear" on your second computer.
First of all understand there are 2 types of security WEP(Wired Equivalent Privacy) and WPA security. WEP is older and easier to hack but is not allowed by some NETGEAR Routers.Wpa is most up to date security. Now back to your solutions follow these steps.
Make sure your computer is connected by Wire to the NETGEAR System.
Open Internet Explorer.
Type www.192.168.0.1 OR www.192.168.1.1 n hit enter.
Now in username type "admin" and in password type "password" (unless not configured)
on the left hand side click "Wireless Settings"
Under " Security Options", select your desired method (preferably WPA2-PSK)
choose Network key it can be anythng from 8-63 characters
