Hi. I disassembled my laptop for cleaning and when I assembled it the display lights are not working. The display itself is working but I need to light it from a certain angle to see a fade picture. There is no signal coming out of the power supply for the lights out of XAD309NR-1WA02309X component in the bottom of the display. All wires are connected well. Is there something else I can do to locate the problem? Thank you, Treechild
It sounds like either the inverter board or the cathode lights behind the screen. I would first suggest double checking the wires coming from the lcd screen connecting directly to the motherboard, follow those wires up and make sure they are properly connected on the other end, then at that point I would normally replace the inverter board, one because its a lot easier and two its usually the inverter board, very rare is it the cathode light that just blows out.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for HP Compaq nx7300 PC Notebook
i have sony vaio vgnfw560f/t with windows 7 ultimate but i cannot use the motion eye. Is there a...
(More)
i have sony vaio vgnfw560f/t with windows 7 ultimate but i cannot use the motion eye. Is there a driver for this?
Hi, I have Hp Compaq nx 7300 with windows Prefession server pack 2. in Bios setting i Select dafault...
(More)
Hi, I have Hp Compaq nx 7300 with windows Prefession server pack 2. in Bios setting i Select dafault setting after that my windows not working in safe mode, normal mode, dos mode and previous setting. when i select any option like safe mode or normal start after 1 minuts same options again comes. And not booting up from CD what should i do.
my compaq nx7300 doesn't recognize Alesis io 14 soundcard partialy, i.e. it is recognized- and...
(More)
my compaq nx7300 doesn't recognize Alesis io 14 soundcard partialy, i.e. it is recognized- and working ok- by Cubase or other stand-alone VST's, but not by the WinMedia player.What can i do? Thank you in advance, Nik
hello,my hp nx7300 is running very slowly;it takes more than an hour to install os.Would you please...
(More)
hello,my hp nx7300 is running very slowly;it takes more than an hour to install os.Would you please tell me somethiong about it thank you!
