Pioneer DVD-U03S SCSI DVD Drive
Problem for Pioneer DVD-U03S SCSI DVD Drive
******Question about Pioneer DVD-U03S!*********
By Cato - usenet poster
I would like to ask if someone knows if the Pioneer DVD-U03S (6X SCSI-2
Slot in style player) is region free or if it has a limit of region code
changes.
If it has a limit of region code changes is it possible to "hack" it?
Thanks a lot
Bye
Solution #1
posted on Aug 09, 2005
Not Rated)
Pasty
Rank: Apprentice
Rating: 0%, 0 votes
Michel R. Carleer schrieb in Nachricht <7apm35$mb @news0.skynet.be>...
Hello Michel!
In my Win 98 System the Pioneer is reported as a Pinoneer DVD 303.
So the RPC Jumper was not removed, puuuh.... :-)
Meanwhile Armageddon runs in my U03S. The problem was the Sofware from
ELSA. (ELSA use the Quadrant Cinemaster DVD Software and labeld it
with their Logo).
I found (after 3 hours web searching :-( ) a registry patch for the Quadrant
Player.
Now it's not possible to play my Code 2 DVD. But that??s only a
Windows - Registry problem... (i hope)
I testet the Xing Player first with the DVD Encore 5x Pack. I installet the
Remote
crack Software and switched between Code 1 and 2. Everthing worked, the Xing
Player too. Now, with the Pioneer DVD Drive in my system, Xing only works
with
Code 2. I think the problem was, that no "remote-sofware" was there to
switch
the Code. So only Code 2 was working...
I can??t find the Software "DVDREGION.EXE" on the web. Can you send me
this file or anyone got an URL for me?
Thank you for helping!
Was this helpful?
Yes
No
Solution #2
Not Rated)
pandamama
Rank: Apprentice
Rating: 0%, 0 votes
I didn't say anything about the RPC jumper!! And I don't have any problem with
the windows98 region code. Now I own a Real magic Holliwood+ with a Toshiba
player and I can change how many times I want the region code thanks to a little
program called Zone selector. I just wanted to ask if the Pioneere DVD-U03S
player is region free or not!!!!!
Bye
"Michel R. Carleer" ha scritto:
Was this helpful?
Yes
No
Solution #3
Not Rated)
Luisa_K
Rank: Apprentice
Rating: 0%, 0 votes
Remember that the DVD player is not the only one to be region code
protected: the software player is also region protected, and the MPEG
decoding card if you use any. Even your operating system can be region
protected: Win98 is. In order to use XingDVD it must be set to the correct
region, and if you work under Win98 it also has to be set to the correct
region. There is a small program to do this, called dvdregion.exe, available
on the net. This program will enable you to change at will the region code
of the common players (XingDVD, Cinemaster, PowerDVD) and of Win98. I don't
remember the URL unfortunately. Can someone help here?
Michel
Was this helpful?
Yes
No
Solution #4
Not Rated)
kcw573
Rank: Apprentice
Rating: 0%, 0 votes
One additional comment: you say you did not remove the RPC jumper. That's
OK, but are you sure somenone did not remove it before you buy it? To be
sure of this, look in Control Panel, System: your drive will be reported as
a CD-ROM and will be called Pioneer DVD 103 if the jumper was never removed,
otherwise it will be reported as Pioneer DVD 103R (notice the additional R).
Michel
Was this helpful?
Yes
No
Solution #5
Not Rated)
Bouncy
Rank: Apprentice
Rating: 0%, 0 votes
Sorry Luca, I was answering Carsten message.
Bye
Michel
<36CFEB3B.809DF @Cybernet-AG.de>...
Was this helpful?
Yes
No
Solution #6
Not Rated)
kioner
Rank: Apprentice
Rating: 0%, 0 votes
I've never removed the RPC-jumper, but I've big problems with the U03S.
Problem 1:
My Armageddon DVD is Code 1. When I try to play it, the Xing DVD-Player
shows
the "FBI-warning", but nothing more. I'm able to copy the "video_ts.vob" on
HD.
But I'm not accessed to start or copy any other file from the DVD under
Windows Explorer.
With a Crative Encore 5x Set DVD Player (Cracked with the Matsushita
firmware)
the Armageddon DVD works 100%!
The Power DVD Player only shows the message:
Error Code: 89010002, Disc has been changed
My other DVD "Perfect Deal" is a German Code 2 version. With this DVD I
don't have any problems.
Problem2:
My original CD-Rom with the ELSAmovie DVD-Player on it, is not able to
be run in the U03S. The drive makes a strange noise, like the optical unit
falls back. It's not possible to start this normal CD-Rom.
My TEAC CD-532S never made any problems like this,  and the
ELSA CD runs fine in it.
With some "burned" CD's the optical unit falls back too, but only for one
second and the drive will work fine.
I can't locate any problems with my other hardware or software. I've tried
everything...
What's wrong????
Alexander Lang schrieb in Nachricht <36CFEB3B.809DF @Cybernet-AG.de>...
Was this helpful?
Yes
No
Solution #7
Not Rated)
Brad
Rank: Apprentice
Rating: 0%, 0 votes
Wow, thanx!!!
Pretty scary!!!
Good thing I never removed it.
Patryk a ??crit dans le message <7al1m2$sr @front2.grolier.fr>...
Was this helpful?
Yes
No
Solution #8
Not Rated)
Cornish
Rank: Apprentice
Rating: 0%, 0 votes
I just bought one today (finally!!! ... very hard to find in Paris/France),
I'm still waiting for my Zone1 DVDs but it seems to be 'Zone Free' according
to a review I saw (of the IDE version). I used a program called 'DRVInfo'
and it says there's no region protection.
So it seems to be ok.
Luca Basile a ??crit dans le message <36CDEE08.259F4 @galactica.it>...
Was this helpful?
Yes
No
Solution #9
Not Rated)
Luisa_K
Rank: Apprentice
Rating: 0%, 0 votes
Never remove the jumper marked RPC though. If you do, the drive will be
permanently regionalized (even if you put back the jumper).
Michel
Was this helpful?
Yes
No
Solution #10
Not Rated)
kioner
Rank: Apprentice
Rating: 0%, 0 votes
As long as you won't remove the RPC-Jumper on the back. So you'd better
never ever remove it!!!
I _love_ this Slot-In loading mechanism!
Greetinx
Harvey
Was this helpful?
Yes
No
Popular Solutions for Pioneer DVD-U03S SCSI DVD
Questions and Unsolved Problems for Pioneer DVD-U03S SCSI DVD
Do you recommend Pioneer DVD-U03S SCSI DVD Drive?
Answer
Answer
the program to run my cd rom has simply vanished from my computor
Answer
my dvd player does not have a sounds when playing dvd's in media player
Answer
I have a Toshiba DVD-ROM Drive, Model No. SD-M1102 from an old HP Pavilion 8370 w/ Windows 98 that I... (More)
Answer
Need your resolution to this issue I am facing with my Sony DVD-RW AW-G170A Drive. 1. The drive... (More)
Answer
It changes from one cd to the next but does not repond to "play" button. I cannot... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Pioneer DVD-U03S SCSI DVD...:
Top DVD Drive Experts
Rank: Guru Guru
Solutions: 14880
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more DVD Drive Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
