Whirlpool GU2400XTP Built-in Dishwasher
Problem for Whirlpool GU2400XTP Built-in Dishwasher
Cloudy will not come off when washed by hand
By mmaynes on Oct 29, 2009
cloudy will not come off when washed by hand almost looked like it looks scratched and and somewhat of a ring look on top and bottom of glass. I have a water softner too.
Solution #1
posted on Nov 10, 2009
Not Rated)
whirlpooltec
Rank: Master
Rating: 88%, 3 votes
If it does not wipe off then this is called "etching" and it is perment damage you can avoid it with certain things. Set your water softener to hardness level of 3-4 grains per gallon. Do not prewash dishes before putting them in, just scrape. Dry without heat aslo will help
Was this helpful?
Yes
No
Solution #2
posted on Nov 09, 2009
Not Rated)
mambro
Rank: Wiz
Rating: 79%, 166 votes
hard water is the problem. go to www.dishwasherfilter.com and get a difi filtration system for your dishwasher. very affordable and works like a charm. no more calcium build up.
Was this helpful?
Yes
No
Solution #3
posted on Oct 29, 2009
Not Rated)
localwonder
Rank: Guru  Whirlpool Expert
Rating: 92%, 3108 votes
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
Also, There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
**Water temperature Note***
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
Concerning the Film.
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner. There are a few out there, Try Dishwasher Magic.
Was this helpful?
Yes
No
Popular Solutions for Whirlpool GU2400XTP Built-in
Questions and Unsolved Problems for Whirlpool GU2400XTP Built-in
Do you recommend Whirlpool GU2400XTP Built-in Dishwasher?
Answer
Answer
It is a Quiet Partner 2. The only number I can see on it is 8575637. The top rack was not getting... (More)
Answer
How to remove lower spray arm whirlpool dishwasher
Answer
The top water sprayer/spinner keeps falling off. I have to remove the top/back water channel to... (More)
Describe your Dishwashers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwasher Experts
Top Dishwasher Repairmen
in Newport, KY
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
