Firstly, there are no belts in the unit.
To remove the hood, you must remove the screws from under the unit, two are hidden by the brush block. The brush block must be pulled down and the latch tabs released on each side to remove it. Then the screws are removed. There is also one screw at the rear of the nozzle area on top, seen when the tank is removed from the base. Lastly, there are mechanical latches on each side, in front of the rear wheels, that are plastic snap tabs. They can be flexed to unlatch.
