Home | Sony | KP-46WT510 46 in. Rear Projection HDTV Tel... | Sony 46 inch proj tv pic...
Sony KP-46WT510 46 in. Rear Projection HDTV Television
Problem for Sony KP-46WT510 46 in. Rear Projection HDTV Television
Sony 46 inch proj tv picture is bowed in the middle and color is
By robertm855 on Oct 29, 2009
picture is bowed in the middle and color is completely out of focus
Solution #1
posted on Nov 03, 2009
Not Rated)
louis66
Rank: Guru  Televisions & Videos  Expert
Rating: 88%, 13 votes
This is a very common failure on Projection TV sets.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • You can see some example photos and find a solution here on Fixya
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Comments:
Nov 07, 2009
- Projection TV sets have several common problems listed below.
Convergence problem.
  • Screen looks 3D
Here are some pics of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button try pressing the button. If it fails to align the video the convergence circuit has failed. See below for a fix.
SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
If you are handy you can do it yourself or you can call in a pro.
If you want to do the repair yourself check the site www.TvRepairKits.com. They have kits that include step by step instructions with photo examples, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, and email/phone support.
Problem #2: Lens Fluid needs replacing!!!
Projection tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant for the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around video.
Here is a pic of a set that needs the fluid changed. Notice how dull the colors are and how white the screen looks. The screen may also look red, orange, dull, etc.
TV set after fluid change. Notice how bright the colors are now. Everthing looks crisp and sharp again.
Solution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant,step by step instructions, etc.
Was this helpful?
Yes
No
Popular Solutions for Sony KP-46WT510 46 in. Rear
Questions and Unsolved Problems for Sony KP-46WT510 46 in. Rear
Do you recommend Sony KP-46WT510 46 in. Rear Projection HDTV Television?
Answer
Answer
I have a Philips Magnavox Projection TV. I had dish satelight install on my TV. It worked well for... (More)
Answer
the tv picture looks like should be wachting it whith 3d glasse
Answer
replaced convergence clips and blue wave will not line up can move but way off
Answer
How do I get the front panel off my Sony 46in projection tv to adjust the red line conversion.
Answer
Our picture is visible but is in blue tint. How much is that to fix, around? Is there anything... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sony KP-46WT510 46 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
