Printer was working fine and I ran out of ink and installed a black and color inkjet cartridges. Now I'm trying to print and I keep getting "check paper". I have checked the paper, checked for misfeeds. Everytime I change the cartridges I have a problem of one kind or another.
In case you thing that the printer looks like to work but the paper doesnot feed, then the problem is mechanical. there is a gear that rotates the rods that feed the paper, which rotates but does not rotate the rod. One can see it only in case you dissasembly the coner from screws. In case you would like to be technical and try, you must takee off the cover by the screws and you will see a big gear on the left side. You must press a little towards the rod, to round it. You muct use a glu carefully, or go to a service to change the gear.
Was this helpful?
Yes
No
Popular Solutions for HP PSC 1315 All-In-One InkJet
I just installed a new HP 78 cartridge into my HP Photosmart 1315 printer and I'm getting a message...
(More)
I just installed a new HP 78 cartridge into my HP Photosmart 1315 printer and I'm getting a message saying the cartridge is not compatible. I double checked and this is the cartridge recommended for this printer. Any advice? Thanks.
if i print something the paper goes into printer and out half way out at the cartrige.The cartrige...
(More)
if i print something the paper goes into printer and out half way out at the cartrige.The cartrige stays to the left jumps up and down and then shows papper jam.same result when i want to coppy.
I have an Epson Stylus Photo RX530 multi function printer. A copy printed from the computer is fine,...
(More)
I have an Epson Stylus Photo RX530 multi function printer. A copy printed from the computer is fine, but a copy of a page placed in the printer is very faint. Everything from the Manual to correct the problem has been tried.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
