Not too bad. Unplug. Remove three screws along back, at top edge. Stand in front of dryer and, using the palms of your hands, push back sharply on the top (L & R sides) to slide it back about 2 inches, then lift top off. Remove 2 phillips head screws at 5 and 7 O'clock position behind door. Remove screws holding top control from top corners. Pull top of control panel loose from retaining clips along top. (watch for sharp edges) Set control panel on top of dryer. Remove 4 screws now accessable at top of front panel. Un-plug light, door switch, lift front panel off, and unplug sensor at bottom. Set front panel aside. Remove 4 screws at front of side panel holding front bulkhead (with drum rollers attached), lift up bulkhead and remove. Reach under drum to unhook belt. Remove drum. The hardest part is pobably hooking the belt back on with the tension pulley while reassembling. On a scale of 1 - 10, it rates about a 5.5. First one might take an hour and a half. If you've done a few, you can knock 'em out in about 20 minutes.
Comments:
Oct 29, 2009
- Wow, you are harsh. Not only do I answer the question of how hard it is, but give the step by step instructions on how to go about doing it, and the best you can do is list it as "somewhat helpful'?
It makes me want to double my rates. Wait. Double FREE is still FREE.
moving my washer and dryer there are some pieces that are to be installed before the move, I don't...
(More)
moving my washer and dryer there are some pieces that are to be installed before the move, I don't have the manuals with me and don't know where the pieces go the washer model is WM2496HFM the Dryer Model DLE9577SM
Purchased an LG LMV1680 on line and it just arrived, still in box. Appears top exhaust vent goes up,...
(More)
Purchased an LG LMV1680 on line and it just arrived, still in box. Appears top exhaust vent goes up, so grills hidden. My problem is wall cabinet over MW extends out 3" from rest of cabinets. This up vent will be under the cabinet, thus blocked. Do they have a reg out facing vent? Thanks, Pete
