ge eterna series dryer.It gets very hot and shut's off until it cools down where it works again. Cleaned lent out of it ,replaced exhaust hose and still over heats. Could it be thermestat?
This is most likely one of the thermostats. One is for high temp, one is for low temp. They are both located on the inside of the back wall on the sheet metal rim that the drum fits into. You have to remove the top and front panel, remove the belt and the drum itself (just pull it straight out through the front of the dryer) to access them. Once you remove all that they are in the upper-left corner of the back wall (if you are looking in from the front of the dryer). They are simple to replace, with only one screw holding them in place. I have an Eterna series and I happen to have it all tore apart right now waiting for the rear bearing I ordered to come in and can see them clearly. If you need photos I will be more than happy to email them to you.
The answer above was incorrect about the wiring, there will be two wires to one and four wires to the other. I believe the one with the four wires is the hi-temp thermostat, but double-check that with your local appliance parts house. If you have it that far apart, you might as well replace the bearing ($11 for mine) and the belt cause they will eventually wear out anyway.
HI. There are a few areas i would advise to check to resolve this issue.
The dryer uses multiple thermostats to regulate the temperature. When the temperature is higher than the preset limit of a particular thermostat, the thermostat breaks the circuit and the heater goes off. When the temperature cools enough, the thermostat closes the circuit again and the heat can come on.
Most dryers have a choice of temperature settings, therefore a separate thermostat is used for each setting. The selector switch or timer control then routes the circuit through the appropriate thermostat.
If a thermostat fails, it may prevent the heat from coming on, This happens because the thermostat does not close the circuit when the temperature falls below the operating temperature of the switch. It is a simple matter to test a thermostat; it should show continuity when the switch is cool and no continuity when it is warmer than its rated temperature.
A thermostat can also fail by being always on, no matter what the temperature. This switch would show continuity whether it was hot or cold. In this case, the heater would not shut off and the the dryer could dangerously overheat. As a safety precaution a second thermostat is used, This is called a thermal fuse. The power will be cut to the heating circuit if the maximum safe temperature is exceeded. In most cases, this is a one time fuse. The heater circuit will not function until the fuse has been replaced. Of course, it will be necessary to determine and repair the underlying cause of overheating or the fuse will just cut out again.
The thermostats are usually grouped together. The are typically oval in shape and about an inch and a half in size. They may be on the blower housing, under the lint trap or inside the vent line. There should be two wires connected to each thermostat.
Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals. You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
To test the thermostats or fuse, set the multimeter to the ohms setting X1. Touch one probe to each terminal. You should get a reading of either zero or infinity. At room temperature, the thermostats should have a reading of zero. When the thermostats are heated to their limit temperature, they should switch off and you should get a reading of infinity. The fuse should be tested at room temperature for continuity. Replace any thermostat or fuse that fails the test.
Was this helpful?
Yes
No
Popular Solutions for GE EWA5600GWW Top Load Washer
My GE Adora front load washing machine will lock the door, spin to the left a couple of seconds,...
(More)
My GE Adora front load washing machine will lock the door, spin to the left a couple of seconds, spin to the right a couple of seconds, then unlock the door. It does this with no water inside and will not cycle at all.
my wife just bought a GE Eterna series washer and dryer set, unfortunately used, and was told they...
(More)
my wife just bought a GE Eterna series washer and dryer set, unfortunately used, and was told they are only 3 years old. the dryer seems fine, but the washer is just loud, so loud i can hear it agitate and spin on the 2nd floor of my home; and they are in the basement. when it is spinning, it will stop. after i lift the lid, set back down, it will spin again for about 2-3 seconds, then stop again. im thinking that the motor is bad or the belt is not on the pullies correctly but i have no idea.....PLEASE HELP!!!
the silver cylinder that you load clothes into has come loose somehow - so it bangs into the sides...
(More)
the silver cylinder that you load clothes into has come loose somehow - so it bangs into the sides of the washer casing really hard. the cylinder seems to not be attached how it should be - too much wiggle to it.
My brand new GE EWA5600GWW washer makes a loud whinning noise after it agitatees. To decress the...
(More)
My brand new GE EWA5600GWW washer makes a loud whinning noise after it agitatees. To decress the noise I have to hold down the front and top panel. Anyone having this problem? It seems the only way to fix is to replace the unit. Thanks.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
