F30 error Fridgidaire Stove/oven...Model PLES389ECC Serial # 54720510.. Stove top works, light in...
(More)
F30 error Fridgidaire Stove/oven...Model PLES389ECC Serial # 54720510.. Stove top works, light in oven comes on..door not locked, warmer will not turn on...we also recently used the warmer for the first time a few days before we noticed the oven problem..and it worked..now it does not...no response when it's controls are pushed. When we try to turn on oven, we get F30 error code...found 4 sensors one showes open the others shows closed when tested with ohm meter. This sensor is located on back, opper right when looking at the back of the oven with cover removed. Can you tell me what sensors (by part number) should read open and which ones should read closed...or do they produce a ohm change, etc. Basically, how do I test each one. Also, is there a reset code/proceedure for the main panel. I am a ET but work on Satcom equipment, not ovens...so I need a little help!!! Thanks, Dan
upper element in oven not working. I am pretty handy and was wondering if it was difficult to...
(More)
upper element in oven not working. I am pretty handy and was wondering if it was difficult to replace or if it was a job for a trained technician.
Our Gallery Professional series oven has a problem. It shakes violently and makes a loud rattling...
(More)
Our Gallery Professional series oven has a problem. It shakes violently and makes a loud rattling sound when the convection roast bake function is turned on. This does not happen when we use the bake function. What is going on? Thanks
PLEF398ACA , the left front element/bridge element switch when turned to front left reads LO on high...
(More)
PLEF398ACA , the left front element/bridge element switch when turned to front left reads LO on high and High on lowest setting. Now the right front large burner boils soup on a 3 setting.
